Make computer to recognize arduino DUE as a MIDI Controller
Hey Guys!
I do a project now, i build a Midi controller. (I hope i can finish it :D) So I have an Arduino DUE, and yet only two buttons connected. I used this example
https://www.arduino.cc/en/Tutorial/MidiDevice
to start testing how native usb thing works.
So the problem is, that i upload the code to the programming port, and native port as well. But programs wont recognize it as a MIDI controller. I tried programs like Resolume, or Ableton Live. I thought it will be easier with this native usb port thing.
Can someone explain me what im doing wrong? :slight_smile: Thx in advance (Code attached below)
Here's my "customized" code. I altered only the number of buttons:
   This examples shows how to make a simple seven keys MIDI keyboard with volume control
   Created: 4/10/2015
   Author: Arturo Guadalupi <a.guadalupi@arduino.cc>
   http://www.arduino.cc/en/Tutorial/MidiDevice
#include "MIDIUSB.h"
#include "PitchToNote.h"
#define NUM_BUTTONS  7
#define C8  108
#define B7  107
#define B7b 106
#define A7  105
#define A7b 104
#define G7  103
#define G7b 102
#define F7  101
#define E7  100
#define E7b 99
#define D7  98
#define D7b 97
#define C7  96
#define B6  95
#define B6b 94
#define A6  93
#define A6b 92
#define G6  91
#define G6b 90
#define F6  89
#define E6  88
#define E6b 87
#define D6  86
#define D6b 85
#define C6  84
#define B5  83
#define B5b 82
#define A5  81
#define A5b 80
#define G5  79
#define G5b 78
#define F5  77
#define E5  76
#define E5b 75
#define D5  74
#define D5b 73
#define C5  72
#define B4  71
#define B4b 70
#define A4  69
#define A4b 68
#define G4  67
#define G4b 66
#define F4  65
#define E4  64
#define E4b 63
#define D4  62
#define D4b 61
#define C4  60
#define B3  59
#define B3b 58
#define A3  57
#define A3b 56
#define G3  55
#define G3b 54
#define F3  53
#define E3  52
#define E3b 51
#define D3  50
#define D3b 49
#define C3  48
#define B2  47
#define B2b 46
#define A2  45
#define A2b 44
#define G2  43
#define G2b 42
#define F2  41
#define E2  40
#define E2b 39
#define D2  38
#define D2b 37
#define C2  36
#define B1  35
#define B1b 34
#define A1  33
#define A1b 32
#define G1  31
#define G1b 30
#define F1  29
#define E1  28
#define E1b 27
#define D1  26
#define D1b 25
#define C1  24
#define B0  23
#define B0b 22
#define A0  21
const uint8_t button1 = 2;
const uint8_t button2 = 3;
const uint8_t button3 = 4;
const uint8_t button4 = 5;
const uint8_t button5 = 6;
const uint8_t button6 = 7;
const uint8_t button7 = 8;
const int intensityPot = 0;  //A0 input
const uint8_t buttons[NUM_BUTTONS] = {button1, button2, button3, button4, button5, button6, button7};
const byte notePitches[NUM_BUTTONS] = {C3, D3, E3, F3, G3, A3, B3};
uint8_t notesTime[NUM_BUTTONS];
uint8_t pressedButtons = 0x00;
uint8_t previousButtons = 0x00;
uint8_t intensity;
  for (int i = 0; i < NUM_BUTTONS; i++)
    pinMode(buttons[i], INPUT_PULLUP);
  readButtons();
  readIntensity();
  playNotes();
// First parameter is the event type (0x0B = control change).
// Second parameter is the event type, combined with the channel.
// Third parameter is the control number number (0-119).
// Fourth parameter is the control value (0-127).
void controlChange(byte channel, byte control, byte value) {
  midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
  MidiUSB.sendMIDI(event);
void readButtons()
    if (digitalRead(buttons[i]) == LOW)
      bitWrite(pressedButtons, i, 1);
      delay(50);
      bitWrite(pressedButtons, i, 0);
void readIntensity()
  int val = analogRead(intensityPot);
  intensity = (uint8_t) (map(val, 0, 1023, 0, 127));
void playNotes()
    if (bitRead(pressedButtons, i) != bitRead(previousButtons, i))
      if (bitRead(pressedButtons, i))
        bitWrite(previousButtons, i , 1);
        noteOn(0, notePitches[i], intensity);
        MidiUSB.flush();
        bitWrite(previousButtons, i , 0);
        noteOff(0, notePitches[i], 0);
        MidiUSB.flush();
// First parameter is the event type (0x09 = note on, 0x08 = note off).
// Second parameter is note-on/note-off, combined with the channel.
// Channel can be anything between 0-15. Typically reported to the user as 1-16.
// Third parameter is the note number (48 = middle C).
// Fourth parameter is the velocity (64 = normal, 127 = fastest).
void noteOn(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
  MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
  midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
  MidiUSB.sendMIDI(noteOff);
You have to use the native port, if it doesn't work, try unplugging it and plugging it back in, and restarting the software. The MIDIUSB library should handle everything for you. Check device manager to make sure that the Arduino is recognized as a MIDI USB device.
You might be interested in my MIDI Controller library.
Pieter
