Hello people,
can I ask you for your help.
I have some sensor, which have two states (HIGH, LOW) and depends of the status I send notification to Telegram.
I not sure, how to make flags - when the status is changed to send just one message to my Telegram until the status change again.
Can you give me hand or example, how to program this ?
Sure, here is a simple example where a flag is used to indicate the on/off state of an LED.
The flag is called ledState.
#define LED 13
const unsigned long eventInterval = 1000000;
unsigned long previousTime = 0;
byte ledState = 0;
pinMode (LED, OUTPUT);
// probably needs loop here:
unsigned long currentTime = micros( );
if (currentTime - previousTime >= eventInterval)
ledState = 1 - ledState; // result is 1, 0, 1, 0 ...
previousTime = previousTime + eventInterval;
digitalWrite (LED, ledState);
Serial.println (previousTime);
} // needs this to end loop()
Not sure, that this help to me.
Mostly like this - i will explain not in programming language:
status = 0
status changed to 1
send notification
status not change -> do nothing
status is changed to 0
send notification
and so on.
There is an example for that:
File->Examples->02.Digital->StateChangeDetection
Looks, this I need ![]()
Just one additional question:
how to read/understand this one :
if (buttonPushCounter % 4 == 0) {
in the example is described, that this is 4 times pushing, but I don't know how this work. What mean %4
That is discussed here
What mean %4
It means divide by 4 and return the remainder.
So
will only be true when buttonPushCounter is exactly divisible by 4
