Make ILI9341 Library for arduino
I’m writing an arduino library for ILI9341 tft display. I tried to write on the display but nothing appears. Why? How can I solve the problem ?
My source code:
/* DISPLAY PINS */
#define LCD_RST A4    //reset
#define LCD_CS A3
#define LCD_RS A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_D0 8
#define LCD_D1 9
#define LCD_D2 2
#define LCD_D3 3
#define LCD_D4 4
#define LCD_D5 5
#define LCD_D6 6
#define LCD_D7 7
/* DISPLAY REGISTERS*/
#define SLEEP_OUT 0x11
#define COLUMN_ADDRESS_SET 0x2A
#define PAGE_ADDRESS_SET 0x2B
#define MEMORY_WRITE 0x2C
#define MEMORY_ACCESS_CONTROL 0x36
#define PIXEL_FORMAT_SET 0x3A
#define POWER_CONTROL_1 0xC0
#define DISPLAY_ON 0x29
//  delay(1000);
    //init serial
    //init digital pins
    initLcdPins();
    delay(100);
    setPower1();
    delay(100);
    memoryAccessControl();
    delay(100);
    setPixelFormat(18);
    delay(100);
    displayOn();
    delay(100);
    delay(100);
    setCol();
    delay(100);
    setPage();
    delay(100);
    writeMemory();
    sleepOut();
// Add the main program code into the continuous loop() function
void initLcdPins() {
    pinMode(LCD_RST, OUTPUT);
    pinMode(LCD_CS, OUTPUT);
    pinMode(LCD_RS, OUTPUT);
    pinMode(LCD_WR, OUTPUT);
    pinMode(LCD_RD, OUTPUT);
    pinMode(LCD_D0, OUTPUT);
    pinMode(LCD_D1, OUTPUT);
    pinMode(LCD_D2, OUTPUT);
    pinMode(LCD_D3, OUTPUT);
    pinMode(LCD_D4, OUTPUT);
    pinMode(LCD_D5, OUTPUT);
    pinMode(LCD_D6, OUTPUT);
    pinMode(LCD_D7, OUTPUT);
    digitalWrite(LCD_RST, HIGH);
    digitalWrite(LCD_CS, HIGH);
    digitalWrite(LCD_RS, HIGH);
    digitalWrite(LCD_WR, HIGH);
    digitalWrite(LCD_RD, HIGH);
    digitalWrite(LCD_D0, 0);
    digitalWrite(LCD_D1, 0);
    digitalWrite(LCD_D2, 0);
    digitalWrite(LCD_D3, 0);
    digitalWrite(LCD_D4, 0);
    digitalWrite(LCD_D5, 0);
    digitalWrite(LCD_D6, 0);
    digitalWrite(LCD_D7, 0);
void setAddress(byte data) {
    //SEND COMMAND TO THE ILI9341
    digitalWrite(LCD_RS, LOW);
    digitalWrite(LCD_WR, LOW);
    delay(10);
    //SET BYTE
    digitalWrite(LCD_D0, (data >> 0) & 0x01);
    digitalWrite(LCD_D1, (data >> 1) & 0x01);
    digitalWrite(LCD_D2, (data >> 2) & 0x01);
    digitalWrite(LCD_D3, (data >> 3) & 0x01);
    digitalWrite(LCD_D4, (data >> 4) & 0x01);
    digitalWrite(LCD_D5, (data >> 5) & 0x01);
    digitalWrite(LCD_D6, (data >> 6) & 0x01);
    digitalWrite(LCD_D7, (data >> 7) & 0x01);
    delay(10);
    delay(10);
    delay(20);
void setParameter(byte data) {
    delay(10);
    //SET BYTE
    delay(10);
    delay(10);
    delay(20);
void setPower1() {
    setAddress(POWER_CONTROL_1);
    setParameter(0x2B);
void setCol() {
    setAddress(COLUMN_ADDRESS_SET);
    setParameter(0x0 );  //SC
    setParameter(0x5);  //EC
void setPage() {
    setAddress(PAGE_ADDRESS_SET);
    setParameter(0x0);  //SC
void writeMemory() {
    setAddress(MEMORY_WRITE);
    for (int i = 0; i < (18*25); i++) {
        setParameter(i);
void setPixelFormat(int format) {
    setAddress(PIXEL_FORMAT_SET);
    if (format == 16) {
        setParameter(0x55);
    else if (format == 18) {
        setParameter(0x66);
void displayOn() {
    setAddress(DISPLAY_ON);
void memoryAccessControl() {
    setAddress(MEMORY_ACCESS_CONTROL);
    setParameter(0x48);
void sleepOut() {
    setAddress(SLEEP_OUT);
The datasheet of the ILI9341: Link
Which of the 12 MCU interfaces did you select?!? In other words, how are pins IM0-IM3 wired?
Your code contains a gruesome amount of delays, I hope nobody is forced to use your library. :-\
What do you miss in the already existing libraries?
