Make led keeps turning on when there is input
I want to know is there any way that makes led keeps turning on after there is no input anymore?
That's far to low with most LEDs; unless you have a special LED, make that e.g. 270 Ohm.
You don't need interrupts for buttons.
If you want to keep your LED on once the pir is triggered, you need a variable that will be set when the pir is triggered and clear that variable when the button is pressed. It could look something like this
  static bool isTriggered = false;
  pirSignal = digitalRead(pir);
  if (pirSignal == HIGH)
    isTriggered = true;
  if (buttonPushed)
  if(isTriggered == true)
    // led on
    // led off
