Hello. How do I keep the LED on, after potentiometer read value changes. I'm completely new to using mills(). Please help me, bright minds.
#define pot A1
int last_pot_read;
last_pot_read = 0;
int new_pot_read = map(analogRead(A1), 0, 900, 0, 8);
if (new_pot_read != last_pot_read){
LED stay ON for duration of X milliseconds, then turn OFF
last_pot_read = new_pot_read;
Take a view in the IDE examples to find the BLINKWITHOUTDELAY example. This example contains the mother of all timers in variations used in the Arduino biotop.
Make a copy and build your own timer as needed simply.
So here is a version that uses my non-blocking timer-function and a flag
#define pot A1
int last_pot_read;
int new_pot_read;
const byte myLED_Pin = 2;
boolean pot_has_changed = false;
unsigned long myLEDTimer;
unsigned long myLED_OnTime = 200;
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
if ( currentMillis - startOfPeriod >= TimePeriod ) {
// more time than TimePeriod has elapsed since last time if-condition was true
startOfPeriod = currentMillis; // a new period starts right here so set new starttime
return true;
else return false; // actual TimePeriod is NOT yet over
last_pot_read = 0;
pinMode(myLED_Pin, OUTPUT);
if (new_pot_read != last_pot_read) {
pot_has_changed = true; // set flag to true
digitalWrite(myLED_Pin, HIGH); // switch LED ON
myLEDTimer = millis(); // initialise Timer-variable with actual time
if (pot_has_changed) {
if ( TimePeriodIsOver(myLEDTimer, myLED_OnTime) ) {
digitalWrite(myLED_Pin, LOW); // switch LED OFF
pot_has_changed = false; // reset flag to false
If this LED shall only be switched on after the pot-value has changed
the state of the IO-pin itself could be used as the flag
#define pot A1
int last_pot_read;
int new_pot_read;
return true;
last_pot_read = 0;
if (digitalRead(myLED_Pin) == HIGH) { // yes you can read the state of an IO-pin configured as output
