So I have a Leonardo which should write a line of text similar to this one: 'qQjyDh48m87L0HY5xtcNNrDrEm_OPcDCHJgMMhu3-pQ='
Now my problem, it seems that the mcu is only capable of writing ASCII characters. (So =, _ and ') don't work if i understand that correctly. Now i wonder if there is a way to actually get the Arduino to write these characters.
PaulS:
How did you get them to appear in your post, then? All three of the characters you mention are in the ASCII table. = is 61, ' is 39, and _ is 95.
I thought those werent in the table because instead of a - I get a ' and the = is the ^ key. This is my actual problem. I tested it with the number and the hex code, still same issue. I have a feeling, that it uses the wrong keyboard layout, but I'm unsure.
