Make my motor turn left and right
Hi, I have build a wheelchair and the motor act like master and slave. So The slave motor will receive signal from the master wheel. I would like to know how can I write my code in order to let them turn left and write. I am using the VESC controller. Thank you
You will need to provide a great deal more information.
And a diagram would probably help.
...R
I actually adapted the idea of electric skateboard but modify it to electric wheelchair. So based on the coding I have, I can only let it to move forward and backward. Then now I am trying to think of how to let the motor turn left and right.
codingnoob:
Well, if you have two wheels, you turn left and right by turning one wheel forward and the other wheel backwards.
That sounds like a very odd arrangement. Why not control the speed and direction of each motor individually ?
Look at your motor. Can it distinguish left from right? Can it ACTUALLY turn right? No. It can ROTATE - clockwise or counterclockwise.
Describing what you want to have happen in terms that match reality is going to be necessary before you can get help here.
