make openwrt-yun error
Hi~.
make openwrt-yun throughout fail.
don’t know where it went wrong.
touch /home/openwrt/openwrt-yun/staging_dir/target-mips_r2_uClibc-0.9.33.2/root-ar71xx/stamp/.kmod-wdt-ath79_installed
WARNING: skipping kmod-pcmcia-au1000 – package not selected
make[3]: Leaving directory /home/openwrt/openwrt-yun/package/kernel' make[2]: Leaving directory /home/openwrt/openwrt-yun’
make[1]: *** [/home/openwrt/openwrt-yun/staging_dir/target-mips_r2_uClibc-0.9.33.2/stamp/.package_compile] Error 2
make[1]: Leaving directory `/home/openwrt/openwrt-yun’
make: *** [world] Error 2
This is nohup.out file.
kally788:
Hi~.
nohup.txt (462 KB)
Did you followed the guide described in the readme?
What operating system are you using?
Angelo9999:
GitHub - arduino/openwrt-yun: A custom version of OpenWrt, targeted to the Arduino Yún
yes. completely in accordance with readme guide
system is debian 6.0.10 (32 bit)
2.6 GHZ CPU (1 core)
1GB memory
60GB disk
nohup.txt (668 KB)
Did you run the build using make or running build.sh?
yes. for the first time use "DL_FOLDER=~/DOWNLOAD ./build.sh"
after failure use "nice -n 10 make -j $MAKE_JOBS V=s"
Angelo9999:
Have tried many times. There is no success.
Hope to get help. Thank you !
kally788:
1GB memory
60GB disk
My compile box:
8 cores
48 GB RAM
240 GB SSD driver
sonnyyu:
My compile box:
8 cores
48 GB RAM
240 GB SSD driver
… my is DIAOSI. no good machine!
Did you try building the base image only?
BUILD_BASE_ONLY=Yes DL_FOLDER=~/DOWNLOAD ./build.sh
Angelo9999:
thank!
try building the base image still wrong.
has uploaded the attachment nohup.txt
rm -rf /home/openwrt/openwrt-yun/tmp/stage-libpcap
touch /home/openwrt/openwrt-yun/staging_dir/target-mips_r2_uClibc-0.9.33.2/stamp/.libpcap_installed
make[3]: Leaving directory /home/openwrt/openwrt-yun/package/libpcap' make[2]: Leaving directory /home/openwrt/openwrt-yun’
nohup.txt (876 KB)
kally788:
thank!
From this "nohup.txt"
make[2]: *** [package/feeds/alljoyn/alljoyn-config/compile] Error 2
make[2]: *** [package/feeds/alljoyn/alljoyn-notification/compile] Error 2
Turn off alljoyn then recompile again
make menuconfig
  Location:                                                             x
  x     -> Network                                                          x
  x       -> alljoyn.................................. AllJoyn Peer-to-Peer  x
sonnyyu:
From this “nohup.txt”
make menuconfig
Location:                                                            x
  x    → Network                                                          x
  x      → alljoyn… AllJoyn Peer-to-Peer  x
thank!
“BUILD_BASE_ONLY=Yes DL_FOLDER=~/DOWNLOAD ./build.sh” is OK.
“DL_FOLDER=~/DOWNLOAD ./build.sh” still fail.
nohup.zip (231 KB)
make[3]: *** [/home/openwrt/openwrt-yun/build_dir/linux-ar71xx_generic/opkg-618/.configured_yyyy] Error 1
Build host file error. very odd.
Start over with faster CPU, more RAM and SSD box? plus some kind of ghost. any odd error I ghost complete compile platform back to SSD driver.
