make pressure sensor - 300 bar air
hello i have a 0 to 400 bar pressure sensor input volt is 5 and out put volt is 0.5 to 4.5 volt dc
any one changes in this code according my sensor
i am beginner please any change as my sensor pacification in this cod
thanks
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display1(OLED_RESET);
Adafruit_SSD1306 display2(OLED_RESET);
const int fpVolts = A0;
int fpSignal = 0;
int fpOutput = 0;
int fpFinal = 0;
const int wbVolts = A1;
int wbSignal = 0;
int wbOutput = 0;
int wbFinal = 0;
int counter1;
const int sampleRate = 0; //in milliseconds
display1.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display2.begin(SSD1306_SWITCHCAPVCC, 0x3D);
void display1Draw(){
display1.clearDisplay();
display1.setTextSize(1);
display1.setTextColor(WHITE);
display1.setCursor(0,0);
display1.println("GAS Pressure:");
display1.setCursor(45,24);
display1.println("BAR");
void display2Draw(){
display2.clearDisplay();
display2.setTextSize(1);
display2.setTextColor(WHITE);
display2.setCursor(0,0);
display2.println("Wideband 02:");
display2.setCursor(95,24);
display2.println("AFR");
void fuelPress() {
fpSignal = analogRead(fpVolts); //Uncomment this to get out of the test version
//test counter
//fpSignal = counter1;
fpOutput = map(fpSignal, 0, 1023, 0, 5000);
fpFinal = ((fpOutput - 500)/40);
String Output;
Output = fpFinal;
if (fpFinal > 344) {
display1.setTextSize(3);
display1.setCursor(0,10);
display1.println("OL");
else if (fpFinal < 0){
display1.println("UL");
else {
display1.println(Output);
void wbAFR() {
//wbSignal = analogRead(wbVolts); //Uncomment this to get out of the test version
//test counter
wbSignal = counter1;
wbOutput = map(wbSignal, 0, 1023, 0, 5000);
String wbFinalStr;
String wholenumber = ("0"); // String for whole number output of our sensor value
int wbcalc = (wbOutput/50*15+735); // Calculation to convert a 0-5V input to the sensor output and stay within a 16 bit integer
String deci = ("0"); // String for decimal output
String wbCalcStr = String(wbcalc); // Converts calculation to string to parse
// Pulls the last 2 characters of the string for our decimal place data
// checks the calculated sensor value so we can decide how far from the left we need to parse the string
// could have also checked the length of the string for validation
if (wbcalc > 999){
wholenumber = wbCalcStr.substring(0,2);
deci = wbCalcStr.substring(2,4);
else if (wbcalc < 999 || wbcalc > 99){
wholenumber = wbCalcStr.substring(0,1);
deci = wbCalcStr.substring(1,3);
else {
wholenumber = ("X");
deci = ("X");
wbFinalStr = (wholenumber + "." + deci);
display2.setTextSize(3);
display2.setCursor(0,10);
display2.println(wbFinalStr);
for (counter1 = 0; counter1 < 1023; counter1++) {
// Fuel pressure gauge display code
display1Draw();
fuelPress();
display1.display();
// Wideband gauge display code
display2Draw();
wbAFR();
display2.display();
delay(sampleRate);
  1. I really suggest you start your own thread.
  2. Explain in detail exactly what your goal is?
  3. What display are you using?
You can't just take a large compilation of code, toss it out there and expect someone to tailor it to your needs. You also don't mention your A/D input voltage?
Ron
@zahidmubeen
TOPIC SPLIT DO NOT HIJACK / NECRO POST !
Other post deleted !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
