Make Program wait for an input
Hi everyone,
I am trying to figure out how to make this program wait until a knock sensor activates it. Tried looking around but don’t understand what I’m doing wrong. Everything in the sketch works until I entered the knock sensor portion. Now nothing happens. I found the “while” idea here but I must be doing it wrong. Any help appreciated.
//Haunted Magic Book project
// Next I will replace each LED with a motor or other function
//adjusting the delays accordingly.
//delays between cases are short for testing. I will increase them later
#include <Servo.h>
Servo myservo;
int pos = 0;
int i = 0;
const int pwmLED = 5;  //fading led
int fadeAmount = 5;                    // how many points to fade the LED by
int leds[8] = {2, 3, 4, 5, 6, 7, 8, 10};    //To control the 8 LEDS--for test only
int ranNum;
int ranDel;
int THRESHOLD = 235;  //how hard to tap on book
byte val = 0;
int KnockSensor = A4;
  Serial.begin  (9600);
  pinMode(2, OUTPUT);  // Setup 8 LEDs as Outputs
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(pwmLED, OUTPUT);
  randomSeed(analogRead(A0));     // unused (floating) analog pin.
//-------------------------KnockSensor--------------------------------------
  val = analogRead(KnockSensor);
  while (val < THRESHOLD) {        //Don't do anything
    while (val >= THRESHOLD) {       //go on
            resume();
void resume()   {                  //begin actions
  digitalWrite (12, HIGH);         //to test peizo knock
  delay(3000);
  digitalWrite (12, LOW);
  ranNum = random(2, 10);      //Generate random number between 8 and 12
  ranDel = random(100, 250);          // random delay time
  int randChoose = random(8);
  switch (randChoose) {     //choose a case
    //-----------------CASES---------
    // ----------------------------------Evil Laughter-------------------- -
    case 0 :  digitalWrite(2, HIGH);  //Play the recording
      delay(2200);
      digitalWrite(2, LOW);
      resume();
    //-------------Book open and close-->WITH LIGHT--------------------------------------
    case 1 :
      myservo.attach(3);
      for (pos = 0; pos <= 35; pos += 1) {   // goes from 0 degrees to 35 degrees  Stepsin steps of 1 degree
        myservo.write(pos);                    // tell servo to go to position in variable 'pos'
        digitalWrite(11, HIGH);                 //Led On
        delay(100);                            // go slowly in this directin
      delay(1500);                            //wait 1.5 sec
      for (pos = 35; pos >= 0; pos -= 1) {     // return to 0 degrees
        myservo.write(pos);
        digitalWrite (11, LOW);               //led low
        delay(15);                               // waits 15ms for the servo to reach the position
      myservo.detach();                          //stop right there before you go any further
      resume();
    //-----------------------------------Unknown---------------------
    case 2 : digitalWrite(4, HIGH);     //turn on led on Pin 4---to be replaced ith an action
      delay(4000);
      digitalWrite(4, LOW);
      resume();
    //-----------------//Green Light Fade IN and OUT  PIN 5 -------------------------------------------
    case 3 :
      for (int i = 0; i < 255; i++) {    //PIN 5 if i is less than 255 then increase i with 1
        analogWrite(pwmLED, i);                //write the i value to pin 5
        delay(20);                             //wait 5 ms then do the for loop again
      for (int i = 255; i > 0; i--) {           //descrease i with 1
        delay(5);
        analogWrite(pwmLED, LOW);                //turn it off
        delay(5);
      resume();
    //---------------------Unknown------------------------
    case 4 :
      digitalWrite(6, HIGH);  //to be replaced with an action
      delay(4000);
      digitalWrite (6, LOW);
      resume();
    //---------------Rumble Motor---------------------------
    case 5 :   digitalWrite(10, HIGH);  //Motor with rumble bar will shake
      digitalWrite(10, LOW);        //stop right there before you go any further
      resume();
    //------------------Book Move----------------------------
    case 6 :  digitalWrite(7, HIGH);   //motor with wheel on bottom will scoot the book slighty
      delay(50);
      digitalWrite (7, LOW);
      resume();
    //--------------------------Book Open And close, No Lights ----------------------
    case 7 :  myservo.attach(3);
        myservo.write(pos);
        delay(20);                               // waits 15ms for the servo to reach the position
      myservo.detach();
      resume();
Try by changing byte val = 0; to int val = 0;.
resume appears to be able to recursively call itself.
That seems to me to be unwise.
Thanks
Okay
Changed val to an integer
deleted "resume"
Still no luck
Sorry. Had to wait 5 min
I'll just add, the sketch works fine without the knock part and a short sketch to test the piezo works.
This is not going to work
            resume();
because nothing changes the content of val inside the WHILE
Try this
…R
Nope
Tried this:
while (val < THRESHOLD) { //Don’t do anything
while (KnockSensor > THRESHOLD) { //go on
I don’t understand while it stops and won’t go on once I tap the sensor.
We can’t see your code
Code again
#include <Servo.h>
Servo myservo;
int pos = 0;
int i = 0;
int ranNum;
int ranDel;
int val = 0;
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  delay(3000);
      delay(2200);
      resume();
    case 1 :
      myservo.attach(3);
        myservo.write(pos);
      resume();
      delay(4000);
      resume();
    case 3 :
        delay(5);
        delay(5);
      resume();
    case 4 :
      delay(4000);
      resume();
      resume();
      delay(50);
      resume();
        myservo.write(pos);
      myservo.detach();
      resume();
resume can call itself recursively.
I thought you said you’d fixed that?
I did remove the one I thought you were speaking about.
I think the Resume(); in the cases is necessary
Polliwog:
OK.
Let us know how it works out.
If I don't use the "void resume" how do I make it return to that point after each case?
1. From literate programming point of you, your loop() function stands as:
    { //go on
2. Do you desire that the codes of the loop() function are designed to do the following?
(1) If val is less than THRESHOLD, there will be no action; the MCU will read the knockSensor again. If so, why don’t you re-write the codes using if-else structure?
(2) If the val value is greater than THRESHOLD, the sketch will be doing something. If so, are you going to call the resume() subroutine? We don’t see any existence of the resume() subroutine in the loop() function.
3. Could your loop() function be written like this?
  if(val > THRESHOLD)
       resume();
Thanks, I'll try this
But you have not put any opinion as to the justification of my moderation on your loop() function.
Hello everyone:
I want to thank you all. With your help and a little more research, I came up with this and the sketch does everything how I wanted it too.
  sensor();
  resume();
void sensor() {
  if (val < THRESHOLD) {
    sensor();
  else  {
    resume();
void resume() {
  delay (1000);
Polliwog:
Nope
Tried this:
Why didn’t you try what I suggested? My suggestion is actually simpler. Why did you add the line
Jeez!
…R
What model Arduino are you using?
Does the knock sensor portion of your code work on its own?
Can you post just the knock sensor code?
Thanks.. Tom...
GolamMostafa:
You were correct, I changed what was in and outside the loop function.
Thanks
