Make Project Charlie's Bear
Hello,
So I have looked around and found similar issues but no solutions to match my specific problem. I an building the RFID talking bear project in Make Magazine v28. I built all the electronics correctly and the RFID software loads and responds correctly. When I go to load the CharliesBear.pde software the arduino software throws many errors. I have included the code/screen shot. This is my first arduino project and the instructions in the magazine just say to upload the .pde and everything should work like magic. All help is appreciated.
Here is the error output:
sketch_dec18a.cpp:3:23: error: FatReader.h: No such file or directory
sketch_dec18a.cpp:4:22: error: SdReader.h: No such file or directory
sketch_dec18a.cpp:5:20: error: WaveHC.h: No such file or directory
sketch_dec18a.cpp:6:22: error: WaveUtil.h: No such file or directory
sketch_dec18a:7: error: 'SdReader' does not name a type
sketch_dec18a:8: error: 'FatVolume' does not name a type
sketch_dec18a:9: error: 'FatReader' does not name a type
sketch_dec18a:10: error: 'FatReader' does not name a type
sketch_dec18a:11: error: 'WaveHC' does not name a type
sketch_dec18a.cpp: In function 'void setup()':
sketch_dec18a:35: error: 'memcard' was not declared in this scope
sketch_dec18a:37: error: 'putstring_nl' was not declared in this scope
sketch_dec18a:43: error: 'memcard' was not declared in this scope
sketch_dec18a:48: error: 'vol' was not declared in this scope
sketch_dec18a:53: error: 'putstring_nl' was not declared in this scope
sketch_dec18a:59: error: 'root' was not declared in this scope
sketch_dec18a:59: error: 'vol' was not declared in this scope
sketch_dec18a:61: error: 'putstring_nl' was not declared in this scope
sketch_dec18a:66: error: 'putstring_nl' was not declared in this scope
sketch_dec18a.cpp: In function 'void cardErrorCheck()':
sketch_dec18a:72: error: 'memcard' was not declared in this scope
sketch_dec18a:73: error: 'putstring' was not declared in this scope
sketch_dec18a:74: error: 'memcard' was not declared in this scope
sketch_dec18a.cpp: In function 'void playfile(char*)':
sketch_dec18a:121: error: 'file' was not declared in this scope
sketch_dec18a:121: error: 'root' was not declared in this scope
sketch_dec18a:123: error: 'putstring_nl' was not declared in this scope
sketch_dec18a:126: error: 'wave' was not declared in this scope
sketch_dec18a:126: error: 'file' was not declared in this scope
sketch_dec18a:127: error: 'putstring_nl' was not declared in this scope
sketch_dec18a:130: error: 'wave' was not declared in this scope
sketch_dec18a.cpp: In function 'void silence()':
sketch_dec18a:134: error: 'wave' was not declared in this scope
Here is the code that the instructions say to upload:
// An interactive bear for Charlie -- RFID triggered sound responses
#include <FatReader.h>
#include <SdReader.h>
#include "WaveHC.h"
#include "WaveUtil.h"
SdReader memcard;
FatVolume vol;
FatReader root;
FatReader file;
WaveHC wave;
#define ENABLE 7      // Set the pin number for enabling the RFID reader. The Audio Shield uses pins 2-5.
#define NUMTAGS 22
int  val = 0;
char code[10];
int bytesread = 0;
char knowntags[NUMTAGS][11] = {"2100DFB002", "2100E0B6ED", "2100DFF660", "2100DFD586", "2100DFB1E5", "2100E0CBAA", "2100E07B21", "2100E0B9D6", "2100D82331", "2100DFA060", "2100DFBC77", "2100DFA69A", "2100D7EFF7", "2100DFE251", "2100E02F09", "2100DFBF83", "2100DFD9EA", "2100E0ABA6", "2100DFDFC4", "2100DFF0DF", "36005B7B50", "36005B7C05"};
char soundfiles[NUMTAGS][9] = {"1000.WAV", "1001.WAV", "1002.WAV", "1003.WAV", "1004.WAV", "1005.WAV", "1006.WAV", "1007.WAV", "1008.WAV", "1009.WAV", "1010.WAV", "1011.WAV", "1012.WAV", "1013.WAV", "1014.WAV", "1015.WAV", "1016.WAV", "1017.WAV", "1018.WAV", "1019.WAV", "1020.WAV", "1021.WAV"};
char filename[1][13];
  //////// Set up RFID reader to collect tag information /////////////////////
  Serial.begin(2400);         // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(ENABLE,OUTPUT);     // Set digital pin 7 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(ENABLE, LOW);  // Activate the RFID reader
  //////// Set the pins to output for driving the Audio Shield
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  ////////// Set up the Audio Shield by initializing the memory card for reading ////////
  if (!memcard.init()) {
    // If something went wrong sdErrorCheck prints out the error check
    putstring_nl("Card init. failed!");
    cardErrorCheck();
    return;
  //This will optimize the reading of the memory card -- remove it if it times out
  memcard.partialBlockRead(true);
  // Find a FAT formatted partition by looking in teh first five slots. Remember your memory card should be FAT16 or FAT32 formatted
  uint8_t partition;
  for (partition = 0; partition < 5; partition++) {
    if (vol.init(memcard, partition))
  if (partition == 5)
    putstring_nl("No valid FAT partition");
    cardErrorCheck();
    while(1); // This is a point of no return. Format your memory card properly and try again.
  // Open the root directory for reading the files
  if (!root.openRoot(vol))
    putstring_nl("Can't open root directory");
    while(1); // Something went wrong here so investigate the file system on your memory card.
  // If you got this far then the card is ready to read
  putstring_nl("Ready to go");
// If we find an error, check what the error is and show it on the serial terminal
void cardErrorCheck(void)
  if(!memcard.errorCode()) return;
  putstring("\n\rSD I/O error:");
  Serial.print(memcard.errorCode());
  putstring(", ");
  Serial.print(memcard.errorData());
  while(1); // Stick here if there is an error
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        playsound(code);
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
        Serial.flush();                  // Flush the serial buffer before trying to read a new code
      bytesread = 0;
void playsound(char codetoplay[]) {
  for(int i = 0; i<8; i++) {    // Make a filename from the first 8 characters of the RFID tag number
    filename[0][i]=codetoplay[i];
  filename[0][8]='.';
  filename[0][9]='w';
  filename[0][10]='a';
  filename[0][11]='v';
  silence(); //shut down anything that is currently playing and close that file
  playfile(filename[0]);
void playfile(char *name) {
  if (!file.open(root, name)) {
      putstring_nl("Couldn't open file");
      return;
   if (!wave.create(file)) {
     putstring_nl("Not a valid WAV");
     return;
  wave.play();
void silence() {
  if(wave.isplaying) {
    wave.stop();
Thanks
There is a thread about this already, see what they are talking about:-
http://arduino.cc/forum/index.php/topic,83016.0/topicseen.html
I looked at this thread before making mine. I did not want to piggy back off of someone else. My issues comes way before this post's topic. I am having an issue compiling the code. I can't even get it to load to the arduino.
What version arduino are you using, it is best to revert to version 0023 for this as issue 1.0 has some compatibility issues.
Basically read the error messages starting at the top. You will see that it can't find a file called FatReader.h: This is a library file, you need to add this library, and all the others that it is complaining about. These folders should be placed in the libraries folder. You might have to track your missing libraries down using google.
