ok so i just finished making plans for a robotic arm.
what is need to know is how can i write the code so
if the pot goes from 0 to 1023. instead of the servo quickly jumping to the position, i want it move slowly (about 180º in 5 seconds)
int targetValue = 1023;
int thisValue = 0;
// get potentiometer value into targetValue here
if(thisValue < targetValue)
thisValue ++;
if(thisValue > targetValue)
thisValue--;
// set servo output here with thisValue
delay(1);
whats another way to do this if you didnt want to use a delay? ie, you wanted to keep your code going fast because you got so much other stuff for it to keep doing. (i need to use an interupt which is measuring the speed of a spinning shaft calculation its RPM)
