I want the bipolar stepper motor to run continuoulsy while reading the load cell. Currently the motor spins then reads the load cell.
#include "HX711.h"
#define DT_PIN 12
#define SCK_PIN 11
#define STEP_PIN 5
#define DIR_PIN 2
#define EN_PIN 8
HX711 scale;
// Variable to store the offset
float offset = 0;
// Define the step delay (in microseconds) to achieve 2000 Hz frequency
unsigned long stepDelay = 250; // 250 microseconds for 2 kHz frequency
unsigned long lastStepTime = 0; // Variable to store the last step time
// Setup serial communication for weight sensor
// Initialize HX711 scale
scale.begin(DT_PIN, SCK_PIN);
scale.set_scale(454.0); // Set the scale to convert readings to pounds
// Calibration: Read initial weight and set it as the offset
Serial.println("Calibrating... Please wait.");
delay(2000); // Wait for 2 seconds to stabilize
offset = scale.get_units(10) / 2; // Take 10 readings and average them to get the offset
Serial.print("Initial offset: ");
Serial.println(offset);
// Setup stepper motor pins
pinMode(STEP_PIN, OUTPUT);
pinMode(DIR_PIN, OUTPUT);
pinMode(EN_PIN, OUTPUT);
digitalWrite(EN_PIN, LOW); // Enable the motor
handleMotorControl();
handleWeightMeasurement();
void handleMotorControl() {
static unsigned long lastStepTime = 0; // To track the last step time
static bool stepState = LOW; // To track the step pin state
// Check if it's time to toggle the step pin
if (micros() - lastStepTime >= stepDelay) {
lastStepTime = micros(); // Update the last step time
// Toggle the step pin state
stepState = !stepState;
digitalWrite(STEP_PIN, stepState);
void handleWeightMeasurement() {
// Get the average value of 10 readings from the scale
float weight = scale.get_units(10) / 2;
// Subtract the offset from the current weight and invert the sign
float adjustedWeight = -(weight - offset);
// Print the adjusted weight to the serial monitor
Serial.print("Weight: ");
Serial.print(adjustedWeight);
Serial.println(" lbs");
