Make two dual-use transceivers communicate each other
I have this specific transceiver (http://www.newark.com/multicomp/mcusd14a40s09rs-30c/transceiver-40khz-14mm-metal/dp/17X2008), and i want to connect two of them on arduino UNO and make them speak each other. How can i accomplish that?
As far as I can see that device is an ultrasonic transducer for use in a parking sensor.
Have you any evidence that two of them can be used for communication?
If so post a link to the evidence.
It also seems from the datasheet that you need an oscillator and other electronics to make it work.
...R
I haven't read the datasheet but I'd think you'd need something like the PCB included in this sensor in order to make it work with a microcontroller.
I doubt it will be easy to use the transducers to communicate. I suppose you could come up with some sort of time dependent communication protocol.
MODERATOR: crosspost removed.
It is a dual use sensor ,so i suppose that it can send and receive signal. The problem is that i can't even make the one to work
Psaras:
What is your response to Replies#1 and #2?
...R
Moderator: another cross post deleted.
Excuse me . I am a beginner in arduino etc. My question is a part of a project that ends in five days ,so i don't have the time to order any farther sensors. Also i don't have evidence or previous experience about those transducers. I connect the one of them like knock sensor (1MΩ resistance etc) and run the knock sensor arduino program but the sensor doesn't respond. I need help about the circuit which i have to create so at least the one sensor works and some help with the arduino programming.
As you don't seem to to have time (or the inclination?) to respond to earlier Replies I don't see how it is possible to help you.
...R
Could you solve the sensor connection problem MCUSD14A48S09RS-30C?
