I am new to programming in C++ with classes. For initializing a PN532 module via SPI i am creating a class with function "initCardreader";
void Cardreader::initCardreader() {
PN532_SPI pn532spi(SPI, 5);
PN532 nfc(pn532spi);
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println("Waiting for an ISO14443A Card ...");
When the module is initialized i want to read a card via an ESP32 task. The function which is called is "scanCard":
void Cardreader::scanCard(void) {
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
The problem is that the nfc variable cannot be found. What is the best way to make the variable not undefined in the scanCard function? How can i make the nfc a private variable or is there a better way?
I am using header files and cpp files (and i am new to this)
lib\Cardreader\Cardreader.cpp: In member function 'void Cardreader::scanCard()':
lib\Cardreader\Cardreader.cpp:44:13: error: 'nfc' was not declared in this scope
You create this variable in a scope of a function, when function is finished, the variable is destroyed. Make it CardReader class member variable and initialise it in CardReader constructor
I did this in the header file but i am not able to get it working:
class Cardreader
private:
Which gives me 2 errors: identifier "PN532" is undefined identifier "pn532spi" is undefined
Also, the initCardreader is called within the setup function, otherwise it won't work and the nfc returns 0 (probably my fault that i am initializing something wrong?)
#include <Arduino.h>
#include <Cardreader.h>
#include <SPI.h>
#include <PN532_SPI.h>
#include <PN532.h>
#include <IPSDisplay.h>
Cardreader::Cardreader(IPSDisplay ipsDisplay)
_ipsDisplay = ipsDisplay;
nfc.begin();
_ipsDisplay.show("/i003");
delay(5000);
initCardreader();
else {
nfc.SAMConfig();
xTaskCreatePinnedToCore(this->scanCard, "scanCard", 5000, this, 1, &task_ScanCard, 0);
void Cardreader::scanCard(void * parameter) {
for(;;) {
uint8_t success;
if (success) {
// Display some basic information about the card
Serial.println("Found an ISO14443A card");
Serial.print(" UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print(" UID Value: ");
nfc.PrintHex(uid, uidLength);
Serial.println("");
if (uidLength == 7)
// We probably have a Mifare Ultralight card ...
Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
// Try to read the first general-purpose user page (#4)
Serial.println("Reading page 4");
uint8_t data[32];
success = nfc.mifareultralight_ReadPage (4, data);
if (success)
// Data seems to have been read ... spit it out
nfc.PrintHexChar(data, 4);
Serial.println("");
// Wait a bit before reading the card again
Serial.println("Ooops ... unable to read the requested page!?");
In file included from src\main.cpp:7:0:
lib\Cardreader/Cardreader.h:19:24: error: 'SPI' is not a type
lib\Cardreader/Cardreader.h:19:29: error: expected identifier before numeric constant
lib\Cardreader/Cardreader.h:19:29: error: expected ',' or '...' before numeric constant
lib\Cardreader/Cardreader.h:20:15: error: 'pn532spi' is not a type
Compiling .pio\build\esp32dev\lib5d8\Cardreader\Cardreader.cpp.o
In file included from lib\Cardreader\Cardreader.cpp:2:0:
lib\Cardreader\Cardreader.cpp: In member function 'void Cardreader::initCardreader()':
lib\Cardreader\Cardreader.cpp:15:5: error: '((Cardreader*)this)->Cardreader::nfc' does not have class type
nfc.begin();
lib\Cardreader\Cardreader.cpp:17:28: error: '((Cardreader*)this)->Cardreader::nfc' does not have class type
lib\Cardreader\Cardreader.cpp:31:9: error: '((Cardreader*)this)->Cardreader::nfc' does not have class type
nfc.SAMConfig();
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
*** [.pio\build\esp32dev\lib5d8\Cardreader\Cardreader.cpp.o] Error 1
The error says from file main.cpp... Are you using the IDE to compile this or something else? SPI gets defined in the esp32/SPI.h file that would automatically be included if you have selected an esp32 board. If you are outside the IDE, I don't know...
