Make'n things turn on and off
hello i has question that maybe someone could help with
i have this code
int ledPin = 3;                // choose the pin for the LED
int inputPin = 9;               // choose the input pin (for PIR sensor)
int photoPin = A0;              // choose the input pin (for photoresistor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the photoresistor value
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  pinMode(photoPin, INPUT);     // declare photoresistor as input
void loop(){
  val = analogRead(photoPin);   // read the value from the sensor
  Serial.println(val);
  if (val > 500) {              // if it's bright turn off the LED
    digitalWrite(ledPin, LOW);
    delay(10);
  if (digitalRead(inputPin) == HIGH) {   // check if the PIR sensor is triggered
    if (pirState == LOW) {
      Serial.println("Motion detected!");
      pirState = HIGH;
      digitalWrite(ledPin, HIGH);
      delay(10);
    pirState = LOW;
and would like to keep the LED off when the photo sensor sees light
no mader if the motion is detected
consider
enum { Off = HIGH, On = LOW };
    if (val > 500 || digitalRead(inputPin) == HIGH)
        digitalWrite(ledPin, On);
        digitalWrite(ledPin, Off);
