Makey Makey door lock system
Hey. I'm trying to build a keyless entry system for my dorm room...I was thinking about trying to connect the output of a makeymakey to an arduino pin and then just set the arduino pin as an input: if that pin is high then move a servo to turn the lock. However, I was wondering if this is actually feasible? and if so do I need to do anything additional to get arduino to recognize the makey makey or otherwise how I might go about doing this? The makeymakey says the output is just high(5v) or low and I tried connecting it to an arduino earlier but with no luck. Thanks for any help you can give
We need a link to the device.
Weedpharma
Hey, Here is a link to the makey makey: http://makeymakey.com/
From looking at the video, it looks like the device has a USB output to a PC. I cannot see any advantage of this device over normal Arduino and sensors.
I would go for something like an iButton, totally unique code in each button.
Or wireless card reader.
Weedpharma
The MakeyMakey is gross overkill for this project. Touch sensor modules cost just a few dollars on eBay.
RFID kits are also very cheap.
I am not sure where you are going to get a sufficiently powerful servo to turn a lock.
