Hi. I am working on doing an Makey Makey demo for some elementary kids next week but I am having some troubles with the source code. I wanted to change the key output but when I compiled the unedited source code it gave me these errors:
The .ino file and the settings.h file are in the same folder. I have been searching all over this forum and other sites for solutions but I couldn't find anything and need to have this figured out by Friday. Thank you for your help.
I can only post once every 5 minutes and there is a limit on how many words per post so stay tuned for the rest of the code.
Arduino: 1.6.13 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino:49:0:
C:\Program Files (x86)\Arduino\libraries\Keyboard\src/Keyboard.h:29:2: warning: #warning "Using legacy HID core (non pluggable)" [-Wcpp]
In file included from C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino:50:0:
C:\Program Files (x86)\Arduino\libraries\Mouse\src/Mouse.h:29:2: warning: #warning "Using legacy HID core (non pluggable)" [-Wcpp]
In file included from C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino:52:0:
settings.h:20: error: 'KEY_UP_ARROW' was not declared in this scope
KEY_UP_ARROW, // up arrow pad
settings.h:21: error: 'KEY_DOWN_ARROW' was not declared in this scope
KEY_DOWN_ARROW, // down arrow pad
settings.h:22: error: 'KEY_LEFT_ARROW' was not declared in this scope
KEY_LEFT_ARROW, // left arrow pad
settings.h:23: error: 'KEY_RIGHT_ARROW' was not declared in this scope
KEY_RIGHT_ARROW, // right arrow pad
settings.h:25: error: 'MOUSE_LEFT' was not declared in this scope
MOUSE_LEFT, // click button pad
settings.h:42: error: 'MOUSE_LEFT' was not declared in this scope
MOUSE_LEFT, // pin A1
settings.h:43: error: 'MOUSE_RIGHT' was not declared in this scope
MOUSE_RIGHT // pin A0
C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino: In function 'void initializeArduino()':
makey_makey:184: error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
Keyboard.begin();
makey_makey:185: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.begin();
C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino: In function 'void initializeInputs()':
makey_makey:229: error: 'MOUSE_LEFT' was not declared in this scope
else if ((inputs[i].keyCode == MOUSE_LEFT) || (inputs[i].keyCode == MOUSE_RIGHT)) {
makey_makey:229: error: 'MOUSE_RIGHT' was not declared in this scope
C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino: In function 'void updateInputStates()':
makey_makey:319: error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
Keyboard.release(inputs[i].keyCode);
makey_makey:334: error: 'Keyboard' not found. Does your sketch include the line '#include <Keyboard.h>'?
Keyboard.press(inputs[i].keyCode);
C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino: In function 'void sendMouseButtonEvents()':
makey_makey:394: error: 'MOUSE_LEFT' was not declared in this scope
if (inputs[i].keyCode == MOUSE_LEFT) {
makey_makey:395: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.press(MOUSE_LEFT);
makey_makey:397: error: 'MOUSE_RIGHT' was not declared in this scope
if (inputs[i].keyCode == MOUSE_RIGHT) {
makey_makey:398: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.press(MOUSE_RIGHT);
makey_makey:402: error: 'MOUSE_LEFT' was not declared in this scope
makey_makey:403: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.release(MOUSE_LEFT);
makey_makey:405: error: 'MOUSE_RIGHT' was not declared in this scope
makey_makey:406: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.release(MOUSE_RIGHT);
C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino: In function 'void sendMouseMovementEvents()':
makey_makey:493: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.move(horizmotion * PIXELS_PER_MOUSE_STEP, vertmotion * PIXELS_PER_MOUSE_STEP);
C:\Users\MAX\Downloads\MaKeyMaKey-master\firmware\Arduino\makey_makey\makey_makey.ino: In function 'void updateOutLEDs()':
makey_makey:688: error: 'TXLED1' was not declared in this scope
TXLED1;
makey_makey:693: error: 'TXLED0' was not declared in this scope
TXLED0;
makey_makey:699: error: 'RXLED1' was not declared in this scope
RXLED1;
makey_makey:704: error: 'RXLED0' was not declared in this scope
RXLED0;
exit status 1
#include "Arduino.h"
// KEY MAPPINGS: WHICH KEY MAPS TO WHICH PIN ON THE MAKEY MAKEY BOARD? //
- edit the keyCodes array below to change the keys sent by the MaKey MaKey for each input
- the comments tell you which input sends that key (for example, by default 'w' is sent by pin D5)
- change the keys by replacing them. for example, you can replace 'w' with any other individual letter,
number, or symbol on your keyboard
- you can also use codes for other keys such as modifier and function keys (see the
the list of additional key codes at the bottom of this file)
int keyCodes[NUM_INPUTS] = {
// top side of the makey makey board
' ', // space button pad
// female header on the back left side
'w', // pin D5
'a', // pin D4
's', // pin D3
'd', // pin D2
'f', // pin D1
'g', // pin D0
// female header on the back right side
MOUSE_MOVE_UP, // pin A5
MOUSE_MOVE_DOWN, // pin A4
MOUSE_MOVE_LEFT, // pin A3
MOUSE_MOVE_RIGHT, // pin A2
// NOISE CANCELLATION /////
#define SWITCH_THRESHOLD_OFFSET_PERC 5 // number between 1 and 49
// larger value protects better against noise oscillations, but makes it harder to press and release
// recommended values are between 2 and 20
// default value is 5
#define SWITCH_THRESHOLD_CENTER_BIAS 55 // number between 1 and 99
// larger value makes it easier to "release" keys, but harder to "press"
// smaller value makes it easier to "press" keys, but harder to "release"
// recommended values are between 30 and 70
// 50 is "middle" 2.5 volt center
// default value is 55
// 100 = 5V (never use this high)
// 0 = 0 V (never use this low
// MOUSE MOTION /////////
#define MOUSE_MOTION_UPDATE_INTERVAL 35 // how many loops to wait between
// sending mouse motion updates
#define PIXELS_PER_MOUSE_STEP 4 // a larger number will make the mouse
// move faster
#define MOUSE_RAMP_SCALE 150 // Scaling factor for mouse movement ramping
// Lower = more sensitive mouse movement
// Higher = slower ramping of speed
// 0 = Ramping off
#define MOUSE_MAX_PIXELS 10 // Max pixels per step for mouse movement
// ADDITIONAL KEY CODES ///
- you can use these codes in the keyCodes array above
- to get modifier keys, function keys, etc
KEY_LEFT_CTRL
KEY_LEFT_SHIFT
KEY_LEFT_ALT
KEY_LEFT_GUI
KEY_RIGHT_CTRL
KEY_RIGHT_SHIFT
KEY_RIGHT_ALT
KEY_RIGHT_GUI
KEY_BACKSPACE
KEY_TAB
KEY_RETURN
KEY_ESC
KEY_INSERT
KEY_DELETE
KEY_PAGE_UP
KEY_PAGE_DOWN
KEY_HOME
KEY_END
KEY_CAPS_LOCK
KEY_F1
KEY_F2
KEY_F3
KEY_F4
KEY_F5
KEY_F6
KEY_F7
KEY_F8
KEY_F9
KEY_F10
KEY_F11
KEY_F12
