Makey makey using arduino uno r3 (Multiple inputs)
I am using arduino uno r3 .I successfully made makey makey using one input.I used 1 mega ohms resistor. Now I am Trying for multiple inputs .When I tried for multiple inputs ,I uploaded the code to my arduino uno r3, and when I connect my arduino unor3 to my computer it prints “wads” when connected. the following is the code.
Please help
#include <HIDKeyboard.h>
#include <MovingAvarageFilter.h>
MovingAvarageFilter movingAvarageFilter(20);
HIDKeyboard Keyboard;
boolean check = false;
boolean check1 = false;
boolean check2 = false;
boolean check3 = false;
Keyboard.begin();
 // declare input and output variables
float input =  analogRead(0);
float input1 =  analogRead(1);
float input2 =  analogRead(2);
float input3 =  analogRead(3);
float output = 0;
float output1 = 0;
float output2 = 0;
float output3 = 0;
output = movingAvarageFilter.process(input);
output1 = movingAvarageFilter.process(input1);
output2 = movingAvarageFilter.process(input2);
output3 = movingAvarageFilter.process(input3);
////  key "w"///////////////////////////////////////////////////
if (output < 300 ) {   // you can change this parameter to fine tune the sensitivity
if (!check){
Keyboard.pressKey('w');
Keyboard.releaseKey();
check = !check;
if (output >600) {
  if (check){
  check = !check;
 ////  key "a"///////////////////////////////////////////////////
if (output1 < 300 ) {   // you can change this parameter to fine tune the sensitivity
if (!check1){
Keyboard.pressKey('a');
check1 = !check1;
if (output1 >600) {
  if (check1){
  check1 = !check1;
  ////  key "d"///////////////////////////////////////////////////
if (output2 < 300 ) {   // you can change this parameter to fine tune the sensitivity
if (!check2){
Keyboard.pressKey('d');
check2 = !check2;
if (output2 >600) {
if (check2){
check2 = !check2;
   ////  key "s"///////////////////////////////////////////////////
 if (output3 < 300 ) {   // you can change this parameter to fine tune the sensitivity
if (!check3){
Keyboard.pressKey('s');
check3 = !check3;
if (output3 >600) {
  if (check3){
  check3 = !check3;
Makey makey multiple inputs.txt (2.33 KB)
This code just screams for arrays.
Here's your problem:
You need one moving average filter for each input. You can't use one to filter all the input.
