Making a 3 axle CNC machine
I now got grbl into the library folder of Arduino. Still things are worrying. Can You hrlp me?
Trying to load it into tyhe Arduino gives the following error message:
In file included from C:\Users\User\Documents\Arduino\libraries\grbl/config.h:30:0,
from C:\Users\User\Documents\Arduino\sketch_mar13b\sketch_mar13b.ino:1:
C:\Users\User\Documents\Arduino\libraries\grbl/grbl.h:68:4: error: #error "Required HOMING_CYCLE_0 not defined."
C:\Users\User\Documents\Arduino\libraries\grbl/grbl.h:108:4: error: #error "WCO refresh must be greater than one."
C:\Users\User\Documents\Arduino\libraries\grbl/grbl.h:111:4: error: #error "Override refresh must be greater than zero."
exit status 1
Error compiling for board Arduino/Genuino Uno.
Moving the statement #include <grbl.h> to the top took the errors away.
What status do my Arduino have now? What is my Arduino capable to now? What can it be used to? How?
I include the message sent:
Sketch uses 30562 bytes (94%) of program storage space. Maximum is 32256 bytes.
Global variables use 1633 bytes (79%) of dynamic memory, leaving 415 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_46563/sketch_mar13b.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file “C:\Users\User\AppData\Local\Temp\arduino_build_46563/sketch_mar13b.ino.hex”
avrdude: writing flash (30562 bytes):
Writing | ################################################## | 100% 6.12s
avrdude: 30562 bytes of flash written
avrdude: verifying flash memory against C:\Users\User\AppData\Local\Temp\arduino_build_46563/sketch_mar13b.ino.hex:
avrdude: load data flash data from input file C:\Users\User\AppData\Local\Temp\arduino_build_46563/sketch_mar13b.ino.hex:
avrdude: input file C:\Users\User\AppData\Local\Temp\arduino_build_46563/sketch_mar13b.ino.hex contains 30562 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 4.77s
avrdude: verifying …
avrdude: 30562 bytes of flash verified
avrdude done. Thank you.
