making a bubble machine with a touch sensor?
alright
using the code that i have here
// CapSense.pde
// Paul Badger 2007
// Fun with capacitive sensing and some machine code - for the Arduino (or Wiring Boards).
// Note that the machine code is based on Arduino Board and will probably require some changes for Wiring Board
// This works with a high value (1-10M) resistor between an output pin and an input pin.
// When the output pin changes it changes the state of the input pin in a time constant determined by R * C
// where R is the resistor and C is the capacitance of the pin plus any capacitance present at the sensor.
// It is possible when using this setup to see some variation in capacitance when one's hand is 3 to 4 inches from the sensors
// Try experimenting with larger sensors. Lower values of R will probably yield higher reliability.
// Use 1 M resistor (or less maybe) for absolute touch to activate.
// With a 10 M resistor the sensor will start to respond 1-2 inches away
// Setup
// Connect a 10M resistor between pins 8 and 9 on the Arduino Board
// Connect a small piece of alluminum or copper foil to a short wire and also connect it to pin 9
// When using this in an installation or device it's going to be important to use shielded cable if the wire between the sensor is
// more than a few inches long, or it runs by anything that is not supposed to be sensed.
// Calibration is also probably going to be an issue.
// Instead of "hard wiring" threshold values - store the "non touched" values in a variable on startup - and then compare.
// If your sensed object is many feet from the Arduino Board you're probably going to be better off using the Quantum cap sensors.
// Machine code and Port stuff from a forum post by ARP  http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169088394/0#0
int  i;
unsigned int x, y;
float accum, fout, fval = .07;    // these are variables for a simple low-pass (smoothing) filter - fval of 1 = no filter - .001 = max filter
int ledPin =  10;    // LED connected to digital pin 10
 pinMode(ledPin, OUTPUT);
DDRB=B101;     // DDR is the pin direction register - governs inputs and outputs- 1's are outputs
// Arduino pin 8 output, pin 9 input, pin 10 output for "guard pin"
//  preceding line is equivalent to three lines below
//  pinMode(8, OUTPUT);     // output pin
//  pinMode(9, INPUT);      // input pin
//  pinMode(10, OUTPUT);    // guard pin
digitalWrite(10, LOW);  //could also be HIGH - don't use this pin for changing output though
y = 0;        // clear out variables
x = 0;
for (i=0; i < 4 ; i++ ){       // do it four times to build up an average - not really neccessary but takes out some jitter
  // LOW-to-HIGH transition
  PORTB = PORTB | 1;                    // Same as line below -  shows programmer chops but doesn't really buy any more speed
  // digitalWrite(8, HIGH);
  // output pin is PortB0 (Arduino 8), sensor pin is PortB1 (Arduinio 9)
  while ((PINB & B10) != B10 ) {        // while the sense pin is not high
    //  while (digitalRead(9) != 1)     // same as above port manipulation above - only 20 times slower!
    x++;
  delay(1);
  //  HIGH-to-LOW transition
  PORTB = PORTB & 0xFE;                // Same as line below - these shows programmer chops but doesn't really buy any more speed
  //digitalWrite(8, LOW);
  while((PINB & B10) != 0 ){            // while pin is not low  -- same as below only 20 times faster
    // while(digitalRead(9) != 0 )      // same as above port manipulation - only 20 times slower!
    y++;
  delay(1);
fout =  (fval * (float)x) + ((1-fval) * accum);  // Easy smoothing filter "fval" determines amount of new data in fout
accum = fout;
Serial.print((long)x, DEC);    // raw data - Low to High
Serial.print( "   ");
Serial.print((long)y, DEC);    // raw data - High to Low
Serial.print( "   ");
Serial.println( (long)fout, DEC); // Smoothed Low to High
if(x > 1) {
  digitalWrite(ledPin, HIGH);
  digitalWrite(ledPin, LOW);
now the interesting part is, when i wire the capacitive touch sensor to the appropriate areas (ie digital pin 8,9, 10 being the mosfet connection), the serial monitor does not produce any values.
I also attached the LED to make sure it lights up, and it doesnt.
You seem to be using pin 10 as part of the capacitive sensor. Have you still got the MOSFET gate attached to pin 10. If so you need to move it to another pin, one not being used by the sensor circuit.
This should not stop things being printed by the monitor. Just to check put a:- Serial.print( "Starting"); in the setup function, just to check you have configured the serial port and monitor correctly.
hmmm this may sound very strange....
i made another touch sensor just using the connections in the MOSFET. Basically, i just touch the resistor and it turns the bubble machine on and off!!!!
Yes that will happen, noise injected from your finger is enough to switch on the MOSFET.
