Making a calculator using an Arduino
Here the updated code. I will appreaciated that you guys look at it and tell me what you think.
   Calculator Version 1.5
   Just add a number enter by the keypad and display it.
   With 2 function : Add / Equal ===> * button
                     Clear ==>  # button
   It will use a MAX7219 for display the data ( for the shiftOut() ).
   and a 4021 for the keypad input data with the use of
   an NOT gate 74HC14. ( for the shiftin() )
   See the keypad example in the tread for details.
   The interrupt use a 72LS20 from the row pins, any LOW signal will
   produce a HIGH pulse to be use has an interrupt signal.
   By Serge J Desjardins
   aka techone / tech37
   Toronto, Ontario, Canada
   Compile and Tested. Still Issues. Maybe it it the Keypad circuit. Not so clean
// Keypad Serial pins
const byte latchkeypin = 10;
const byte datakeypin = 12;
const byte clockkeypin = 11;
// Display Serial pins
const byte datadisplaypin = 9;
const byte clockdisplaypin = 8;
const byte latchdisplaypin = 7;
// Anykey and interrupt pin
const byte anykeypin = 2;
// MAX7419 init data
word initdata[5] = { 0x0C01, 0x0F00, 0x0A0B, 0x0B07, 0x09FF };
// Fill the Display array with a blank code
word display_data[8] = { 0x0100, 0x020F, 0x030F, 0x040F, 0x050F, 0x060F, 0x070F, 0x080F };
// The digit array
byte digit_number[8] = {0,0,0,0,0,0,0,0};
// The second array - The total number
byte add_number[9] = {0,0,0,0,0,0,0,0,0};
// Key press keypad flag
volatile boolean keystate;
// Overflow flag
boolean over_flow;
// add button flag
boolean add_flag;
// Clear button flag
boolean clear_flag;
// The keypad data
byte keydata;
byte keynumber;
// The choice
byte choise;
  //start serial
  //Serial.begin(9600);
  //define the pins modes
  pinMode(latchkeypin, OUTPUT);
  pinMode(clockkeypin, OUTPUT);
  pinMode(datakeypin, INPUT);
  pinMode(datadisplaypin, OUTPUT);
  pinMode(clockdisplaypin, OUTPUT);
  pinMode(latchdisplaypin, OUTPUT);
  pinMode(anykeypin, INPUT);
  // setup the interrupt pin
  attachInterrupt(0,anykeypress,RISING);
  /* Init the MAX7419 : Normal Mode
                        Normal Operation
                        Setting the Intensity
                        Numbers of Digits being display
                        Set to Decode Mode
  for (int i=0;i<5;i++)
     digitalWrite(latchdisplaypin, LOW);
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, highByte(initdata[i]));
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, lowByte(initdata[i]) );
     digitalWrite(latchdisplaypin, HIGH);
     delay(5);
  // Blank the display
  display_the_numbers();
  // init the flags and the calculation variable
  keystate = 0;
  add_flag = 1;
  over_flow = 0;
  clear_flag = 1;
  while ( keystate == 0)
     // wait for a key press
  read_keypad();
  convert_the_keypad_data();
  // The choise 1 = numbers , 2 = add , 3 = clear
  switch (choise)
     case 1 :
             entry_of_numbers();
             break;
     case 2 :
             add_section();
             break;
     case 3 :
             clear_section();
             break;
// Choise 1
void entry_of_numbers()
  // Enter the numbers routine
  if ( over_flow == 0 )
     if ( ( add_flag == 1) && ( clear_flag = 1 ) )
       for (int i=0;i<8;i++)
         digit_number[i] = 0;
         display_data[i] = word ( ( i+1 ), 0x0F );
     // Enter the key number and move the arrays data.
     for (int i=7;i>0;i--)
       digit_number[i] = digit_number[i-1];
       display_data[i]=display_data[i-1];
       display_data[i] = word ( (i+1) , lowByte( display_data[i] ) );
     digit_number[0] = keynumber;
     display_data[0] = word ( 1, keynumber );
     add_flag = 0;
     clear_flag = 0;
     keystate = 0;
// Choise 2 - the add section
void add_section()
    // Check for the "Add / Equal" button
         add_number[i] = add_number[i+1] + add_number[i] + digit_number[i];
         if ((add_number[i] > 0x09) && (add_number[i] < 0x14) )
           add_number[i+1] = 1;
           display_data[i] = word ( ( i + 1 ), ( add_number[i] - 10 ));
            display_data[i] = word ( ( i + 1 ) , add_number[i]);
      // check for over flow
      if ( add_number[8] != 0)
        over_flow = 1;
        digit_number[0] = 0;
        display_data[0] = 0x010B;
        for ( int i=1;i<8;i++)
           display_data[i] = word( (i+1), 0x0F );
        keystate = 0;
        over_flow = 1;
        add_flag = 1;
        keystate = 0;
        over_flow = 0;
        add_flag = 1;
// Choise 3 - The clear section
void clear_section()
    // Check for the "Clear" button
      add_number[0] = 0;
      display_data[0] = 0x0100;
        add_number[i] = 0;
      add_number[8] = 0;
      keystate = 0;
      over_flow = 0;
      add_flag = 1;
      clear_flag = 1;
  //For troubleshooting the program using Serial Monitor
    Serial.print(keydata, BIN);
    Serial.print("  ");
    Serial.print(keydata, HEX);
    Serial.print("  ");
    Serial.print(keynumber, HEX);
    Serial.print("  ");
    Serial.println(keydata, DEC);
// Read keypad data via a 74HC14 - Inverter from the 4021
void read_keypad()
  digitalWrite(latchkeypin,HIGH);
  delayMicroseconds(20);
  digitalWrite(latchkeypin,LOW);
  keydata = shiftIn(datakeypin, clockkeypin,LSBFIRST);
// Convert the keypad data into BCD
// And a code for *, 0, # button
void convert_the_keypad_data()
  byte what_row;
  what_row = ( keydata >> 3) & 0x0F;
  switch ( what_row)
    case 1:
           keynumber = ( ( keydata >> 1 ) & 0x03 ) + 1;
           choise = 1;
           break;
    case 2:
           keynumber = (( keydata >> 1 ) & 0x03 ) + 4;
           choise = 1;
           break;
    case 4:
           keynumber = (( keydata >> 1 ) & 0x03 ) + 7;
           choise = 1;
           break;
    case 8:
           special_key();
           break;
// the display the data routine to the MAX7219
void display_the_numbers()
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, highByte(display_data[i]) );
     shiftOut(datadisplaypin, clockdisplaypin, MSBFIRST, lowByte(display_data[i]) );
     delay(5);
// A special code for 0, *, # button
void special_key()
   byte special_case;
   special_case = ( ( keydata >> 1) & 0x03 ) + 1;
   switch ( special_case )
     case 1:
            keynumber = 0x0E;
            choise = 3;
            break;
     case 2:
            keynumber = 0x00;
            choise = 1;
            break;
     case 3:
            keynumber = 0x0B;
            choise = 2;
            break;
// Interrupt Routibe
void anykeypress()
  keystate = 1;
