Making a countdown
I need to make an alarm that 1) makes a sound and "agitates" a servo when it detects light and b) the push of a button adds 30 seconds to a timer, and when it get to 0, does the same stuff.
I'm a little new, but I thought this would be straight forward. I got the photoresistor part just fine, and at the push of a button, it displays a 30 second timer that counts down to 0.
However the alarm, agitate(), does not go off when it reaches zero and I have no idea if I'm missing something simple or am actually doing it wrong. Starts about 5 lines into void loop:
#include <LiquidCrystal.h>
#include <Servo.h>
LiquidCrystal lcd(12,11,5,4,3,2);
Servo servo;
int sensorValue;
int speakerPin = 8;
int switchState = 0;
double timer = 0;
boolean switchClosed = false;
boolean alarmOn = false;
  lcd.begin(16, 2);
  servo.attach(9);
  pinMode(7, INPUT);
}//end setup
  sensorValue = analogRead(A0);
  //Serial.println(sensorValue);
  switchState = digitalRead(7);
  //SETTING BY SWITCH//
  if(switchState == HIGH){
    switchClosed = true;
    timer += 30;
  if(switchClosed == true){
    for(int i = timer; i > 0; i--){
      timer--;
      lcd.setCursor(4,0);
      lcd.print(timer);
    alarmOn = true;
  //PHOTORESISTOR//
  if(sensorValue > 100){
    alarmOn = true;
  if(sensorValue < 100){
    alarmOn = false;
    noTone(speakerPin);
  if (alarmOn == true){
    agitate();
}//end loop
void agitate(){
  tone(speakerPin, 392);
  servo.write(0);
  servo.write(150);
Try commenting out this section as a test:
//  if(sensorValue < 100){
//    alarmOn = false;
//    noTone(speakerPin);
I think you're turning the alarm on, then immediately turning it off.
Oh wow, yep that was it, I'll have to adjust it. Thank you very much!
