Hi everyone, i have a little problem and my c++ skills are pretty rusty since i mostly did C for years.
I am trying to remove that rust by writing small libs in cpp, which allows me to clean some projects i have.
If that has any influence, please note i use both esp8266 and arduinos.
Right now i have been converting a basic set of logging functions into a class, with some macros to disable it when the debugging is over and we want to reduce memory footprint… but for this to work, il requires the instance to have a specific name: Logger.
And for the life of me, i cannot make it to work .
If i declare “LogManagement Logger;” in the .cpp file,with “extern LogManagement Logger;” in the header guards in the .h file i get this error:
error: ‘Logger’ was not declared in this scope
If i declare it in the .h file, i get a link error saying it was already declared (not surpising) .
If i declare it in the .h file inside the header guards and the extern directive in the other part of the header guard, i am back to the first error.
If i declare it in the .ino file, it compiles with no error, but i do not want to have it there.
My question is:
how do I Instantiate that lib class with the name Logger inside my library, so there is no need to instantiate it in the .ino file, just like we use the Serial class ? I tried to find how this one works but could not find it.
Thanks a lot.
Here is the code:
LogManagement.h
#ifndef _CGE_LOG_MANAGEMENT_H
#define _CGE_LOG_MANAGEMENT_H
#ifdef NEED_LOG
#ifdef NEED_QUEUE_LOG
#define LOG(x) {do {Serial.print(x); Logger.addLog(x);)}while(0);}
#define LOG_LN(x) {do {Serial.println(x); Logger.addLog(x);}while(0);}
#else
#define LOG(x) {Serial.print(x);}
#define LOG_LN(x) {Serial.println(x);}
#endif
#else
#define LOG(x) {}
#define LOG_LN(x) {}
#endif
#include <queue>
#include <ostream>
#include <string>
#include "arduino.h"
#define CGE_MAX_LOG_COUNT 12
using namespace std;
class LogManagement
public:
LogManagement(int maxLogCount= CGE_MAX_LOG_COUNT);
~LogManagement(void);
void begin(void);
void addLog(int logToAdd);
void addLog(string &logToAdd);
void addLog(char * logToAdd);
string getOneLog(void);
string getAllLogs(bool withBrSeparator);
private:
int _maxLogCount;
queue<string*> _logQueue;
#endif
LogManagement.cpp
#include "LogManagement.h"
LogManagement::LogManagement(int maxLogCount)
if (maxLogCount > CGE_MAX_LOG_COUNT)
maxLogCount =CGE_MAX_LOG_COUNT;
_maxLogCount = maxLogCount;
LogManagement::~LogManagement(void)
while(!_logQueue.empty())
delete _logQueue.front();
_logQueue.pop();
string LogManagement::getOneLog(void)
string str("");
if (!_logQueue.empty())
string *pStr = _logQueue.front();
str.append(*pStr);
delete pStr;
_logQueue.pop();
return str;
string LogManagement::getAllLogs(bool withBrSeparator)
string str("");
str.append(*pStr);
if (withBrSeparator)
str.append("
str.append("\n");
delete pStr;
_logQueue.pop();
return str;
// iostream lib too big to be included ...
//istream &operator>>( istream &input, LogManagement &Obj)
/* check if we reached max size, and if so, cleanup */
// while (_logQueue.size() >= _maxLogCount)
// delete _logQueue.front();
// _logQueue.pop();
/* now insert the new element */
// string *pStr = new string(input);
// _logQueue.push(pStr);
void LogManagement::addLog(int logToAdd)
char tmpBuffer[60];
snprintf(tmpBuffer,59,"%d",logToAdd);
addLog(tmpBuffer);
void LogManagement::addLog(char * logToAdd)
string str(logToAdd);
addLog(str);
void LogManagement::addLog(string &logToAdd)
_logQueue.pop();
string *pStr = new string(logToAdd);
void LogManagement::begin(void)
simpleExample.ino
#define NEED_LOG 1
#define NEED_QUEUE_LOG 1
#include <string>
void setup(void)
Logger.begin();
void loop(void)
LOG_LN("test log1")
LOG_LN("test log2")
LOG_LN("test log3")
string str = Logger.getOneLog();
Serial.println(str.c_str());
str = Logger.getAllLogs(false);
