I need a code that when I send a letter to the serial port from my PC, it takes the code and makes an equation (a=hello,b=bye,c=idk) than prints the result to my 16-pin LCD screen.
If someone could help me, It would be great
What have you tried? What were the results?
The serial input basics tutorial may be a starting point?
Have you got the lcd screen working, just to print a "hello world" type message as a test? If not, start there
Then have a look at example 1 here (edit: same link as previous post), and instead of just printing the character out, use it in an "if" and then output the appropriate text.
Show us a good schematic of your circuit.
Show us a good image of your wiring.
Give links to components.
Posting images:
https://forum.arduino.cc/index.php?topic=519037.0
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
Well, I figured out how to make it work. But thanks to everyone that tried to help me
Gklp:
That's great, but for those of us who read the forum to pick up tips and learn from others, how about posting your solution and giving a little back?
GM
