Hello users.
I am currently making a "Fridge" like program, where I need the arduino board to start cooling when it's over 25 Degrees celcius, and stop cooling when it's below 23 degrees celcius.
This is using the DHT Library
This what I've so far.
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
int cooler = 12;
Serial.println("DHTxx test!");
pinMode(cooler, OUTPUT);
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C");
if (t <= 24) {
digitalWrite(cooler, LOW);
Serial.print ("Stopped Cooling");
else (t >= 25)
digitalWrite(cooler, HIGH);
Serial.print(" Start Cooling");
This won't say anything inbetween the 24-25 period, so it's doesn't cooldown, how could I fix this?
