Making a HC-SR04 Ultrasonic sensor work with an LED and photocell
Hi
I am making a robot using an Arduino Uno board. This robot is supposed to be able to sense light and move towards it. While doing so, if there are any obstacles within 10cm, it indicates with the LED set to on and stops the motor. However, I have been unable to get the LED to indicate when the robot gets to close to an obstacle or stop the motor. Please can someone help, this is my code:
// Pins
const int PWMB = 8;
const int BIN2 = 9;
const int BIN1 = 10;
const int AIN1 = 11;
const int AIN2 = 12;
const int PWMA = 13;
const int SW_PIN = 7;     // Switch to turn the motors on and off
const int LIGHT_PIN = A0; // Photocell
const int LED = 2;        //LED
const int echoPin = 5;
const int trigPin = 6;
// Constants
const int SEARCH_DRIVE_TIME = 200;  // Time to run one motor while searching
const int TURN_DRIVE_TIME = 200;    // Time to turn in a direction
const int MOVE_DRIVE_TIME = 300;   // Time to drive in a direction
const int STOP_DRIVE_TIME = 200;    // Time to stop after moving
const int NUM_LIGHT_LEVELS = 3;
long duration, distance;
 // Set switch pin
 pinMode(7, INPUT_PULLUP);
 pinMode(5, INPUT);
 // Set the motor control pins as outputs
 pinMode(6, OUTPUT);
 pinMode(11, OUTPUT);
 pinMode(12, OUTPUT);
 pinMode(13, OUTPUT);
 pinMode(10, OUTPUT);
 pinMode(9, OUTPUT);
 pinMode(8, OUTPUT);
 pinMode(2,OUTPUT);
 // Initialize Serial comms
 Serial.println("Let's get this Light ");
 digitalWrite(6, LOW);
 delayMicroseconds(5);
 // Trigger the sensor by setting the trigPin high for 10 microseconds:
 digitalWrite(6, HIGH);
 delayMicroseconds(10);
 // Read the echoPin, pulseIn() returns the duration (length of the pulse) in microseconds:
 duration = pulseIn(5, HIGH);
 // Calculate the distance:
 distance= duration*0.034/2;
 if (distance < 10)
   {(digitalWrite(2,HIGH));
 else {
   (digitalWrite(2,LOW));
 // Print the distance on the Serial Monitor:
 Serial.print("Distance = ");
 Serial.print(distance);
 Serial.println(" cm");
 // Store light levels as array [left, center, right]
 int light_levels[3];
 // If switch is flipped, search for light
 if (digitalRead(7) == LOW){
   // Record light value to the left
   drive(0, 255);
   delay(200);
   drive(0, 0);
   delay(200);
   light_levels[0] = analogRead(A0);
   drive(0, -255);
   delay(200);
   drive(0, 0);
   delay(200);
   // Record light value to the right
   drive(255, 0);
   delay(200);
   drive(0, 0);
   delay(200);
   light_levels[2] = analogRead(A0);
   drive(-255, 0);
   delay(200);
   drive(0, 0);
   delay(200);
   // Record light value in the center
   light_levels[1] = analogRead(A0);
   // Find direction of max light
   int max_light = 0;
   int max_light_index = 0;
   for ( int i = 0; i < 3; i++ ) {
     if ( light_levels > max_light ) {
       max_light = light_levels;
       max_light_index = i;
     Serial.print(light_levels);
     Serial.print(" ");
   Serial.print("Max light: ");
   Serial.println(max_light_index);
   // Move in the direction of max light
     if ( max_light_index == 0 ){
     Serial.println("Checking for brightest light on the left");
     drive(-100, 255);
     delay(200);
     drive(255, 255);
     delay(300);
     drive(0, 0);
     delay(200);
     else if ( max_light_index == 1 ) {
     Serial.println("Checking for brightest light straight ahead");
     drive(255, 255);
     delay(300);
     drive(0, 0);
     delay(200);
     else {
     Serial.println("Checking for brightest light to the right");
     drive(255, -100);
     delay(200);
     drive(255, 255);
     delay(300);
     drive(0, 0);
     delay(200);
 // If switch is not flipped, do nothing
   digitalWrite(5,LOW);
   digitalWrite(6,LOW);
   drive(0, 0);
void rightMotor(int motorSpeed)
 // If speed is positive, run the motor forward
 if (motorSpeed > 0) {
   digitalWrite(11, HIGH);
   digitalWrite(12, LOW);
 // If it's negative, run the motor backward
 } else if (motorSpeed < 0) {
   digitalWrite(11, LOW);
   digitalWrite(12, HIGH);
 // If it's 0, brake the motor
 analogWrite(13, abs(motorSpeed));
void leftMotor(int motorSpeed)
   digitalWrite(10, HIGH);
   digitalWrite(9, LOW);
   digitalWrite(10, LOW);
   digitalWrite(9, HIGH);
 analogWrite(8, abs(motorSpeed));
void drive(int leftSpeed, int rightSpeed) {
 leftMotor(leftSpeed);
 rightMotor(rightSpeed);
You gave all your pins nice meaningful names, then didn't use them.
Please rectify.
You need to use code tags.
Please rectify
OK.
Now go and read the forum instructions so that you can go back and modify your original post (not re-post it - using the "More -> Modify" option below the right hand corner of your post - to mark up your code as such using the "</>" icon in the posting window. Just highlight each section of code (or output if you need to post that) from the IDE and click the icon.
In fact, the IDE has a "copy for forum" link to put these markings on a highlighted block for you so you then just paste it here in a posting window. But even before doing that, don't forget to use the "Auto-Format" (Ctrl-T) option first to make it easy to read.
If you do not post it as "code" it can as you now see, be quite garbled and is always more difficult to read.
It is inappropriate to attach it as a ".ino" file unless it is clearly too long to include in the post proper. People can usually see the mistakes directly and do not want to have to actually load it in their own IDE. And that would also assume they are using a PC and have the IDE running on that PC.
Also tidy up your blank space. Do use blank lines, but only single blanks between complete functional blocks.
