Making a library object from scratch
I have been following the tutorial about making the Morse library:-
I don't have a problem with understanding the code, but I'm using the Arduino IDE, & I'm struggling with the processing of those files. The IDE seems to require me to save my source files as .ino. I tried making the folder "Morse" in my "libraries" folder, and using Notepad to make the source files & save them as ../libraries/Morse/Morse.cpp & .h. I'm rather expecting some sort of language processor to convert these into some intermediate (object?) format file to be "linked?" with the main program, but I haven't grasped the mechanism of doing that, & that part doesn't seem to be covered in the tutorial - or I have overlooked it.
Using the Arduino IDE, can I make my own library object programmed in c++?
Can anyone point me at some tutorial or reference document that covers the language processing part of that, as opposed to explaining the c++ language.
I'm working on a microsoft windows PC.
You don't make library objects. The library source is part of the project compile.
I'm not sure in what sense you are using the word "object" here. Libraries are source files.
Make a folder. Put a .cpp file in it. Put a .h file in it. Put that folder into the "libraries" folder under your sketches folder. Restart the IDE so it notices. Done.
tip: use notepad++ it has syntax highlighting ! and if you use the textfx plugin you have c++ indenting etc.
Thanks Rob. I guess I was surprised that, essentially, your library module contains c++ objects, but the IDE doesn't provide a supportive development environment for that.
Since posting, I have moved away from bothering with the library. I'm just putting my object definitions & implementations into the main file, so the whole of my program resides in a single .ino file. When I started, I wanted to capitalise on the encapsulation capability of objects; separating out the major functional aspects into distinct sections of the file. So I had already positioned my data, albeit global data, spread through the source file in order to put it with the parts of code that acted on it.
I then moved on to coding c++ objects in-line & lo, it worked! So I can program my arduino in c++ using the standard IDE. I had been somewhat misguided in thinking I could only write in something that looked fairly close to vanilla c, although I was aware that I could use objects, as evidenced by the Serial facility. It just seemed pretty odd that I could have an object from a library, but no program development capability for it in the IDE, & an IDE that seemed to be blocking me from editing .h or .cpp files.
Note to self. ... I must check out whether Arduino provides "new" & "delete". I'm guessing the answer is probably no. With just 2k bytes of RAM to play with, what chance of fitting a heap into that?
There is no need to guess. Try it and see (that it does).
This Arduino beast is definitely growing on me.
