Making a library to increase a function with analog value
Hi, I have this function which increases a variable when a analog value is given to it. Eg, low analog value would increase/decrease the value a little over time and a higher analogvalue would then increase the value a lot over time.
But here is the questions.
How should I go about expanding this library?
  1. Make it work with floats, longs doubles, what ever input type you want.
  2. Make it a pointer based and a return based. Eg, call the update function and it updates the pointer given to it.
like this
int valueToBeUpdated = 0;
void functionThatWouldUpdateValue();
I think you would have to pass the &memory location in the intilization part and & or pointer which the update function would get the analog value from.
Have a function that would mass update all of the objects.
I would like to have a function that I can pass function pointers to and that function would then call the update with a single line.
  1. Have some optional arguments like deadzone and max/min value. I know how to implement theese but not elegantly.
if(inputvalue < deadzone || deadzone < inputvalue){
and to return the max I could just use a ternary.
return (input < max) ? input : max;
But not sure how to have this with pointer.
Thanks for the help!
Forgot to include the source files!
analogIncrease.cpp (554 Bytes)
analogIncrease.h (484 Bytes)
seems like you're talking about several different things
  • i think you're describing a class, not necessarily a library
  • i don't see the update() identified in the .h, wouldn't it be the function used to update the value and shouldn't it be public and shouldn't it return the updated value
  • don't see inputArray[] nor understand why you would need such
  • not sure what you mean by value type -- the value provided to the class or the value maintained and returned. (why not just do everything with doubles)
  • don't understand low, high and changeby. seems you would have a threshold above which you adjust the value by a large amount and below which you adjust by a small amount. are low/high the adjustment values or thresholds
  • don't understand the purpose of a deadzone. is the deadzone around the threshold
  • additional parameter (i.e. max, min can always be set in the constructor but need to be defined
  • are there just 5 parameters: min, deltaLow, thresh, deltaHigh, max?
in C++ Programming Style Cargill discusses poorly designed classes, showing examples, discussing their flaws and how to improve them
consider
class AnalogIncrease {
    double _min;
    double _delLo;
    double _thresh;
    double _delHi;
    double _max;
    double _val;
  public:
    AnalogIncrease (double min,
                    double delLo,
                    double thresh,
                    double delHi,
                    double max )
        _min    = min,
        _delLo  = delLo,
        _thresh = thresh,
        _delHi  = delHi,
        _max    = max;
        _val    = 0;
    double value (void)   { return _val; };
    double update (double val)  {
        if (_val < val)  {
            Serial.print   (_val);
            Serial.print   (" < ");
            Serial.print   (val);
            Serial.println ("  greater");
        if ( _thresh < val)
            _val += _val < val ? _delHi : -_delHi;
            _val += _val < val ? _delLo : -_delLo;
        return _val;
AnalogIncrease ai (10, 1, 50, 5, 100);
void loop (){
    char s [40];
    if (Serial.available ())  {
        int n = Serial.readBytesUntil ('\n', s, sizeof(s));
        s [n] = 0;
        Serial.println (ai.update (atof(s)));
void setup () {
    Serial.begin (9600);
