MAKING A NUMBER CONVERSION SYSTEM IN PROTEUS USING ARDUINO
//I was trying to correct this code but i am not getting it right as i am still getting errors when i run it in the //compiler any1 to help , heres a link to the project description //Number conversion by Arduino – ECENGCATION?
I can see neither 'this code' nor the errors you are getting!
Please post both here.
Fix the stray '\xxx' errors, and it compiles fine.
I don't have the hardware(edit: Proteus? Neither do you?), so I can't test it (nor do I want to - the code is awful)
Hint: They may look like double quotes or a "minus minus" decrement operator, but aren't.
I am having a hard time removing all the stray errors because i am new to arduino IDE and c++ anyone to help?
#include<LiquidCrystal.h>
/Connected RS of LCD to A0 EN to A1 D4 to D7 to A2 to A5 Respectively/
LiquidCrystal lcd(A0,A1,A2,A3,A4,A5);
int NumberToBeDisplayed = 0;
int TempNum = 0;
/Rows of keypad connected to D6-D9 of Arduino/
int r1=6;
int r2=7;
int r3=8;
int r4=9;
/Colums of keypad connected to D10-D13 of Arduino/
int c1=10;
int c2=11;
int c3=12;
int c4=13;
/Declared four variable to read colums status/
int col1;
int col2;
int col3;
int col4;
/Declared Row pins as OUTPUT/
pinMode(r1,OUTPUT);
pinMode(r2,OUTPUT);
pinMode(r3,OUTPUT);
pinMode(r4,OUTPUT);
/Declared Column pins as OUTPUT/
pinMode(c1,INPUT);
pinMode(c2,INPUT);
pinMode(c3,INPUT);
pinMode(c4,INPUT);
digitalWrite(c1,HIGH);
digitalWrite(c2,HIGH);
digitalWrite(c3,HIGH);
digitalWrite(c4,HIGH);
pinMode(4,OUTPUT);
/lcd brightness terminal connected/
digitalWrite(4,0);
lcd.begin(16,2);
lcd.setCursor(0,0);
lcd.print(“A:Oct B:Binary”);
lcd.setCursor(0,1);
lcd.print(“C:Hex D:Decimal”);
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
lcd.setCursor(0,1);
digitalWrite(r1,LOW);
digitalWrite(r2,HIGH);
digitalWrite(r3,HIGH);
digitalWrite(r4,HIGH);
col1=digitalRead(c1);
col2=digitalRead(c2);
col3=digitalRead(c3);
col4=digitalRead(c4);
if(col1==LOW)
lcd.print(“1”);
delay(50);
NumberToBeDisplayed = (NumberToBeDisplayed10) + 1;
while(digitalRead(c1) == LOW);
else if(col2==LOW)
lcd.print(“2”);
delay(50);
10) + 2;
while(digitalRead(c2) == LOW);
else if(col3==LOW)
lcd.print(“3”);
delay(50);
NumberToBeDisplayed = (NumberToBeDisplayed10) + 3;
while(digitalRead(c3) == LOW);
else if(col4==0)
lcd.clear();
lcd.print(“—- OCTAL —–“);
lcd.setCursor(0,1);
TempNum = ConvertDecimalToBase(NumberToBeDisplayed,8);
lcd.print(TempNum);
while(digitalRead(c4) == LOW);
digitalWrite(r1,HIGH);
digitalWrite(r2,LOW);
if(col1==LOW)
lcd.print(“4”);
delay(50);
10) + 4;
else if(col2==LOW)
lcd.print(“5”);
delay(50);
NumberToBeDisplayed = (NumberToBeDisplayed10) + 5;
else if(col3==LOW)
lcd.print(“6”);
delay(50);
10) + 6;
else if(col4==LOW)
delay(50);
lcd.clear();
lcd.print(“—- BINARY —-“);
lcd.setCursor(0,1);
for(int i=15;i>=0;i–)
lcd.print((NumberToBeDisplayed >> i & 1));
digitalWrite(r3,LOW);
if(col1==LOW)
lcd.print(“7”);
delay(50);
NumberToBeDisplayed = (NumberToBeDisplayed10) + 7;
else if(col2==LOW)
lcd.print(“8”);
delay(50);
10) + 8;
else if(col3==LOW)
lcd.print(“9”);
delay(50);
NumberToBeDisplayed = (NumberToBeDisplayed10) + 9;
else if(col4==LOW)
delay(50);
lcd.clear();
lcd.print(“- HEXADECIMAL –“);
lcd.setCursor(0,1);
TempNum = NumberToBeDisplayed;
ConvertDecimalToHex(TempNum);
digitalWrite(r4,LOW);
if(col1==LOW)
delay(50);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
else if(col2==LOW)
lcd.print(“0”);
delay(50);
10) + 0;
else if(col3==LOW)
delay(50);
lcd.clear();
lcd.setCursor(0,1);
lcd.print(TempNum);
lcd.clear();
lcd.setCursor(0,1);
lcd.clear();
lcd.setCursor(0,1);
lcd.clear();
lcd.print(“— DECIMAL —-“);
lcd.setCursor(0,1);
lcd.print(NumberToBeDisplayed);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
lcd.setCursor(0,1);
else if(col4==LOW)
delay(50);
lcd.clear();
lcd.setCursor(0,1);
int ConvertDecimalToBase(int n, int b)
int r=0, digitPos=1;
while (n)
r += (n%b)digitPos;
n /= b;
digitPos = 10;
return r;
void ConvertDecimalToHex(long int num)
long int rem[50],i=0,length=0;
while(num>0)
rem
=num%16;
  • num=num/16;*
  • i++;*
  • length++;*
  • for(i=length-1;i>=0;i–)*
    _ switch(rem*)_
    _
    {_
    _
    case 10:_
    _
    lcd.print(“A”);_
    _
    break;_
    _
    case 11:_
    _
    lcd.print(“B”);_
    _
    break;_
    _
    case 12:_
    _
    lcd.print(“C”);_
    _
    break;_
    _
    case 13:_
    _
    lcd.print(“D”);_
    _
    break;_
    case 14:
    lcd.print(“E”);
    case 15:
    lcd.print(“F”);
    default :
    _lcd.print(rem);
    }*_
If you copy that back, you'll probably find the unnamed errors magically fixed. You'll have put the missing array indices back.
Please remember to use code tags when posting code
Thank you...
@mufika_shiwomwenyo
Please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
