Greetings,
I'm trying to develop an UART reader with my ESP32-2432s028 (a.k.a. cheap yellow display), the idea is a black terminal on the screen and every time it reads a line from the serial pins (35 for RX and 22 for TX) it writes the data on the bottom on the terminal, and when it reaches the end of the line, everything shifts up and it starts writing again on the start of the bottom line.
I've found out that the TFT_eSPI library (the one i'm using), doesn't support a "shift screen", so I've found a code on the internet that works sending indivilual commands to the display to shift up, but I want it to work on Landscape mode, but when I put the screen in Landscape mode it just shifts to the left, but I want it to shift up in Landscape mode, but it doesn't exists the command to shift the screen up in Landscape mode, even chatGPT couldn't help me, so I would be gratefull if you could help me, thanks!
(I want to have the possibility to scroll up too to see old Serial data that got past the screen when scrolling if possible)
Heres the code I have found for vertical mode scrolling:
This sketch implements a simple serial receive terminal
program for monitoring serial debug messages from another
board.
Connect GND to target board GND
Connect RX line to TX line of target board
Make sure the target and terminal have the same baud rate
and serial settings!
The sketch works with the ILI9341 TFT 240x320 display and
the called up libraries.
The sketch uses the hardware scrolling feature of the
display. Modification of this sketch may lead to problems
unless the ILI9341 data sheet has been understood!
Updated by Bodmer 21/12/16 for TFT_eSPI library:
https://github.com/Bodmer/TFT_eSPI
BSD license applies, all text above must be included in any
redistribution
#include <TFT_eSPI.h> // Hardware-specific library
#include <SPI.h>
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
// The scrolling area must be a integral multiple of TEXT_HEIGHT
#define TEXT_HEIGHT 16 // Height of text to be printed and scrolled
#define BOT_FIXED_AREA 0 // Number of lines in bottom fixed area (lines counted from bottom of screen)
#define TOP_FIXED_AREA 16 // Number of lines in top fixed area (lines counted from top of screen)
#define YMAX 320 // Bottom of screen area
#define RXp2 35
#define TXp2 22
// The initial y coordinate of the top of the scrolling area
uint16_t yStart = TOP_FIXED_AREA;
// yArea must be a integral multiple of TEXT_HEIGHT
uint16_t yArea = YMAX-TOP_FIXED_AREA-BOT_FIXED_AREA;
// The initial y coordinate of the top of the bottom text line
uint16_t yDraw = YMAX - BOT_FIXED_AREA - TEXT_HEIGHT;
// Keep track of the drawing x coordinate
uint16_t xPos = 0;
// For the byte we read from the serial port
byte data = 0;
// A few test variables used during debugging
bool change_colour = 1;
bool selected = 1;
// We have to blank the top line each time the display is scrolled, but this takes up to 13 milliseconds
// for a full width line, meanwhile the serial buffer may be filling... and overflowing
// We can speed up scrolling of short text lines by just blanking the character we drew
int blank[19]; // We keep all the strings pixel lengths to optimise the speed of the top line blanking
// Setup the TFT display
tft.init();
tft.initDMA();
tft.setRotation(0); // Must be setRotation(0) for this sketch to work correctly
tft.fillScreen(TFT_BLACK);
// Setup baud rate and draw top banner
Serial2.begin(115200, SERIAL_8N1, RXp2, TXp2);
tft.setTextColor(TFT_WHITE, TFT_RED);
tft.fillRect(0,0,240,16, TFT_RED);
tft.drawCentreString("UART Terminal - 115200 baud",120,0,2);
// Change colour for scrolling zone text
tft.setTextColor(TFT_WHITE, TFT_BLACK);
// Setup scroll area
setupScrollArea(TOP_FIXED_AREA, BOT_FIXED_AREA);
// Zero the array
for (byte i = 0; i<18; i++) blank[i]=0;
void loop(void) {
// These lines change the text colour when the serial buffer is emptied
// These are test lines to see if we may be losing characters
// Also uncomment the change_colour line below to try them
// if (change_colour){
// change_colour = 0;
// if (selected == 1) {tft.setTextColor(TFT_CYAN, TFT_BLACK); selected = 0;}
// else {tft.setTextColor(TFT_MAGENTA, TFT_BLACK); selected = 1;}
while (Serial2.available()) {
data = Serial2.read();
// If it is a CR or we are near end of line then scroll one line
if (data == '\r' || xPos>231) {
xPos = 0;
yDraw = scroll_line(); // It can take 13ms to scroll and blank 16 pixel lines
if (data > 31 && data < 128) {
xPos += tft.drawChar(data,xPos,yDraw,1);
blank[(18+(yStart-TOP_FIXED_AREA)/TEXT_HEIGHT)%19]=xPos; // Keep a record of line lengths
//change_colour = 1; // Line to indicate buffer is being emptied
// Call this function to scroll the display one text line
int scroll_line() {
int yTemp = yStart; // Store the old yStart, this is where we draw the next line
// Use the record of line lengths to optimise the rectangle size we need to erase the top line
tft.fillRect(0,yStart,blank[(yStart-TOP_FIXED_AREA)/TEXT_HEIGHT],TEXT_HEIGHT, TFT_BLACK);
// Change the top of the scroll area
yStart+=TEXT_HEIGHT;
// The value must wrap around as the screen memory is a circular buffer
if (yStart >= YMAX - BOT_FIXED_AREA) yStart = TOP_FIXED_AREA + (yStart - YMAX + BOT_FIXED_AREA);
// Now we can scroll the display
scrollAddress(yStart);
return yTemp;
// Setup a portion of the screen for vertical scrolling
// We are using a hardware feature of the display, so we can only scroll in portrait orientation
void setupScrollArea(uint16_t tfa, uint16_t bfa) {
tft.writecommand(ILI9341_VSCRDEF); // Vertical scroll definition
tft.writedata(tfa >> 8); // Top Fixed Area line count
tft.writedata(tfa);
tft.writedata((YMAX-tfa-bfa)>>8); // Vertical Scrolling Area line count
tft.writedata(YMAX-tfa-bfa);
tft.writedata(bfa >> 8); // Bottom Fixed Area line count
tft.writedata(bfa);
// Setup the vertical scrolling start address pointer
void scrollAddress(uint16_t vsp) {
tft.writecommand(ILI9341_VSCRSADD); // Vertical scrolling pointer
tft.writedata(vsp>>8);
tft.writedata(vsp);
