Can you please help me to make a code using if statements that will enable the servo motor to run if the sensor input becomes 1.
Which part are you stuck with. Use the Servo Sweep example as a basis. Add a digitalRead() to see if your switch is on.
Simple servo button test code.
//zoomkat servo button test 12-29-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
pinMode(button1, INPUT);
pinMode(button2, INPUT);
servo1.attach(7);
digitalWrite(4, HIGH); //enable pullups to make pin high
digitalWrite(5, HIGH); //enable pullups to make pin high
press1 = digitalRead(button1);
if (press1 == LOW)
servo1.write(170);
press2 = digitalRead(button2);
if (press2 == LOW)
servo1.write(10);
/*else {
servo1.write(90);
