I have been wanting to make an automatic dog feeder for a while, and I just got a servo motor. My plan is to hook a servo up to my Arduino Uno and somehow make it so that at a chosen time it will activate the servo for a given amount of time. I am new to programming with Arduinos and I would appreciate any help I could get. Thanks, Cowen.
If you are going to have this running for more than a day or two and you don't want the times to drift several minutes a day then you should get a Real-Time Clock (RTC) module to keep the time and date.
If you want the servo to move once a day, pick an hour and minute. Make sure the clock is in 24-hour mode or you will get feedings every 12 hours instead of 24.
Then you can move the servo for one minute a day:
if (now.day == 13 &&now.minute == 0) // 1 PM every day
servo.write(180);
servo.write(0);
You might want to add a prox detector so the "whatever" doesn't close on the dog's head after a minute...
aarg:
I assumed that the servo would just be dumping a serving of food into a bowl.
I am very sorry, but I was hoping to be able to feed my dog twice a day, is there any way to do that?
programmingisfun:
What times? 9 AM and 7 PM?
if ((now.hour == 9 && now.minute == 0) // 9 AM every day
or
(now.hour == 19 && now.minute == 0)) // 7 PM every day
servo.write(180);
servo.write(0);
johnwasser:
What times? 9 AM and 7 PM?if ((now.hour == 9 && now.minute == 0) // 9 AM every day
or
servo.write(180);
servo.write(0);
I tried that, but when I go to upload it to my Arduino Uno, a message pops up saying "now was not declared in this scope.
/tmp/563348960/sketch_sep8a/sketch_sep8a.ino:15:18: error: expected ')' before ';' token
/tmp/563348960/sketch_sep8a/sketch_sep8a.ino:15:19: error: expected primary-expression before ')' token
exit status 1"
Is there any fix for this? Sorry for all of the trouble.
programmingisfun:
The fix is to connect the RTC (which you will have to buy) and use a matching library to get the current Hour and Minute. Use those values for now.hour and now.minute.
