making a webserver that will run all the time
when I use the example of web server
it's only working when I connect to it ,
I want to make it work even when no one is connected to it.
now it will only show me data when I connect to it using the ethernet cable (my code is to count how many people move in front of my PIR)
I want it to always run ,and when I connect it will continue normally.
what do I need to change?
#include <SPI.h>
#include <Ethernet.h>
int david;
int directtion_switch=7;//????? ????? ?????
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };//mac address of the device
IPAddress ip(10,0,0,25);// ip address of the device
EthernetServer server(80);
{//start of setup
  delay (1000);
  pinMode(9,INPUT);
  pinMode(8,INPUT);
  pinMode(directtion_switch,INPUT);
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  Serial.println("please waite while run startup...");
  for (int i=0;i<10;i++)
    Serial.print("**");
    delay (1000);
  Serial.println("");
  Serial.println("Thank you");
  Serial.println("Sensor is now active");
}//end of setup
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Refresh: 1");  // refresh the page automatically every 1 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          //******************************************* the part of the code*******************//////////
          david=work();
          int Possition_switch=poss();
          Serial.println(Possition_switch);
          if  (Possition_switch==1)
            client.println("The entry is from left side  ");
            client.print(">>>>>>>>>>>>>>>>>>>>>>>>>>>>");
            client.println("
          else if (Possition_switch==0)
            client.println("The entry is from right side  ");
            client.print("<<<<<<<<<<<<<<<<<<<<<<<<<<<<");
            client.println("
          if (david==0)
            client.print("NO MOVE  ");
            client.println("
            if (david==1)
              client.print("move right-->left ");
              client.println("
              if (david==2)
                client.print("move left-->right ");
                client.println("
          //**************** end part of the code ***************
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
int work()//   ???? ???? ????? ???? ????
  int PIR;
  int right=digitalRead(9);
  int left=digitalRead(8);
  if ((left==HIGH)&(right==HIGH))
    Serial.println("no move ");
    PIR=0;
  {//start of move
    if ((left==LOW)&(right==HIGH))
    {//fist move 1
      Serial.println("move1");
      PIR=1;
    }//end move1
      if ((left==HIGH)&&(right==LOW))
        Serial.println("move2");
        PIR=2;
  }//end of move
  return PIR;
}//end work
int poss()// ????? ????? ??? ???
  int poss_temp;
  if (digitalRead(directtion_switch==HIGH))
    poss_temp=0;
    Serial.println("entry from right side -->>>> ");
  else if (digitalRead(directtion_switch==LOW))
    poss_temp=1;
    Serial.println("entry from left side -----<<< ");
  return poss_temp;
}//end of poss
I'm not sure what you mean, but most "work" when there are no clients. Here is my basic server code.
http://playground.arduino.cc/Code/WebServerST
Here is one of my posts with a server that does a few things like dns and ntp, and reports the status of the sockets while doing it.
http://forum.arduino.cc/index.php?topic=167184.msg1364572#msg1364572
let me explain what I want to do -
I have a PIR sensor and the code is counting how many time someone moved in front of it.
my problem is that - the program begin to work only when I connect to the ip at the first time .(
so if I don't enter the site(10.0.0.25) it will not begin running the code and I won't know how many people have moved,
(even when I don continually ping to the IP - 10.0.0.25 )
You should have taken a look at that second link I posted for you. It does that.
  // check for movement here
  // now listen for incoming clients
  if (client) {
// rest of your server code
if I understand you correctly
I need to change the order of my code?
at the start of the loop to do the code I want and what\how to count
and in the end of the loop "publish " it?
Check movement every iteration of loop(). When you get a client, then publish your movement results.
edit: In other words, yes. The sketch in that second link checks the time (millis), and if it is time for a dns and ntp update, it does a dns request for Google, then an NTP request for the time, then checks for a server client.
O.k. ,
now it's good - thanks for this
now I have another question - when I close the serial monitor and then open it again - the counter reset to 0 .
it there a way to keep the value ? until the next reset of the device or until I disconnect it from power?
Thank ,
The usb port triggers a reset when you connect to it. There are two solutions.
  1. Install a capacitor on the reset line from the usb chip to the Arduino.
  2. Cut the "RESET EN" trace on the Arduino.
I don't use #1. I get the feeling that may overload the reset line when it tries to pull that cap low.
edit: If you cut the "RESET EN" trace, you must press the reset button to upload new code to the Arduino. You can enable it again by a small solder jumper across the "RESET EN" pads.
In the past I've defeated the arduino reset by putting a 100 ohm resistor between the reset pin and +5v pin. Easy to remove/replace. YMMV
I will try it - and tell if its work
Thank (for the 2 suggestions )
