Making an Audio File Play With A Sensor
I have been working for weeks to solve this and I can't figure it out, though I am new to Arduino.
I have tried DFplayer and WTV020 and I can't figure out how to make them work with a temperature sensor. I have tried DHT11/22 and TMP36.
Using the example code for DFplayer is an absolute nightmare, I can't figure out how to simply play it through an if statement, I really need help before I tear my hair out. Thanks!
Well start off by saying what you want to do, the details you have given so far are vague to say the lease.
Through?
Please read this:-
How to use this forum it will tell you how to ask a question and how to post stuff as attachments. Then you need to post the best attempt at the code you have made so far. Finally you need to post a schematic of what you have.
I must say I can't see much use for making a temperature measurement while playing a file so explaining your end goal is also useful.
I just did this yesterday, using the Catalex YX-5300 module. the DF player is apparently a YX-5200 module. the YX-5300 module is the same thing, with a Serial interface. I am assuming you have the chops to get Serial working. the whole sketch is 27K and growing; I am only including the code related to sound here. it isn’t for compiling, it’s for studying:
12 sensors, active low, 12 folders, containing sounds ranging from bird tweets to “lock and load, incoming!”. It works in the sense that pulling a pin low causes noise to come out, I don’t have it at right folders for individual sensors yet
no library required:
// YX5300 Sound Module
#define CMD_SEL_DEV 0X09
              #define DEV_TF 0X02
#define CMD_SET_VOLUME 0X06
//#define CMD_PLAY_W_VOL 0X22
//#define CMD_PLAY 0X0D
#define CMD_PLAY_W_INDEX 0X03
#define CMD_PLAY_FOLDER_FILE 0X0F   // 0x7E 06 0F 00 01 02 EF;( play folder 01/002.wav )
//#define CMD_PAUSE 0X0E
//#define CMD_PREVIOUS 0X02
//#define CMD_NEXT 0X01
// YX-5300
static unsigned char Send_buf[8] = {0} ;
delay(500);//Wait chip initialization is complete
      sendCommand(CMD_SEL_DEV, DEV_TF);                 //select the YX5300 TF card
      delay(200);//wait for 200ms
      sendCommand(CMD_SET_VOLUME, 0x06001e);    // you have to set the sound volume first, to know if it's alive
      //sendCommand(CMD_PLAY_W_INDEX, 0X030001);          // play the first sound file on the root directory to verify operation. plays on upload and on reset
// YX5300 sound module functions //////////////////////////////////////////////////////////////////////////////
void playWAV (int sw) // sw is the counter in a loop
 switch (sw)  // switch / case is a better choice than if / then for many purposes
    case 0:  // Zone 0 Administrator Log In // press a concealed button to verify you are home, and to get past "Zone 1 is on pin 0, Zone two is on pin 1..."
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0102);  // Play the 2ndfile on folder 00
      break;  // you are done with Zone 0 action, return
    case 1:  // Zone 1 Outer Marker // 400 foot driveway
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0101);  // Play a single note file from folder 01
    case 2:  // Zone 2 Inner Marker // 50 foot driveway enters property
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0201);  // Play a double note file from folder 02
    case 3:  // Zone 3 Curtilage
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0301);  // Play a triple note file from folder 03
    case 4:  // Zone 4 DMZ
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0401);  // Play a 4 ships bell file from folder 04 // neighbor was in the Merchant Marine, his initials are DM...
    case 5:  // Zone 5 North Side Entry
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0501);  // Play an alarm sound from folder 05
    case 6:  // Zone 6 North Side No Pass
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0506);  // Play an alarm sound from folder 05
    case 7:  //
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0503);  // Play an alarm sound from folder 05
    case 8:  //
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0601);  // Play an alarming sound from folder 06
    case 9:  //
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0602);  // Play an alarming sound from folder 06
    case 10: //
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0603);  // Play an alarming sound from folder 06
    case 11: //
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0609);  // Play an alarming sound from folder 06
    case 12: // Public Doorbell
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0610);  // Play an innocuous sound from folder 12
    case 13: // DBFH
      sendCommand(CMD_PLAY_FOLDER_FILE, 0X0F0304);  // Play an obnoxious sound from folder 13
    default:
      // if nothing else matches, do the default
      // default is optional
void sendCommand(uint8_t command, int16_t dat)
  delay(20);
  Send_buf[0] = 0x7e;    //starting byte
  Send_buf[1] = 0xff;    //version
  Send_buf[2] = 0x06   ; //the number of bytes of the command without starting byte and ending byte
  Send_buf[3] = command; //
  Send_buf[4] = 0x00;    //0x00 = no feedback, 0x01 = feedback
  Send_buf[5] = (int8_t)(dat >> 8);//datah
  Send_buf[6] = (int8_t)(dat); //datal
  Send_buf[7] = 0xef; //ending byte
  for(uint8_t i=0; i<8; i++)//
    Serial2.write(Send_buf[i]);
this gets me one squeak, squawk, ding, gong, et cetera per pin pulled low. it assembles a command string and sends it through a serial port to the YX-5300.
