Making an Electric Skateboard with control
Hello i have done this project where i build a electric skateboard But need some help with coding and wiring of the controller
So the wiring of the skateboard look like this:
https://ggyazo.com/329882ddb9295fc7a328900f12ce2a61
The red board that is connected to the ESC is the receiver which look like this:
https://gyazo.com/1223b7fedae7738ed925673e3dcbaeb2
And to that there is a transmitter that look like this:
https://gyazo.com/3db8bc74223914219fe95c0e13a71b1c
And i wonder how i can connect and program the arduino together with the transmitter and receiver and with the help of a potentiometer control the speed of the motor on skateboard? and also how i can add a button to the controller so i can turn it on and off.
And also if i could add a led which activates when the battery percentage is like 20%
What are all the components i need to accomplish this and how do i do it??
I need a bit of help with the coding and wiring and how i can do this!
The basic coding i have is this:
#include <SoftwareServo.h>
int potentiometer=A7;
int potval;
int curval;
SoftwareServo ESC;
 pinMode(potentiometer, INPUT);
 ESC.attach(9);
 curval=0;
 ESC.setMinimumPulse(800);
 ESC.setMaximumPulse(2000);
 potval=analogRead(potentiometer);
 potval=map(potval,0,1023,0,180);
 while(curval<potval){
   curval=curval+1;
   ESC.write(curval);
   SoftwareServo::refresh();
   Serial.println(curval);
   delay(50);}
 while(curval>potval){
   curval=curval-1;
   ESC.write(curval);
   delay(50);}
   ESC.write(curval);
Like would that work? or do i need to change/add anything?
So basically what i want is when i turn the potentiometer i change the speed of the motor on the skateboard!!
What do i need and how do i do it??
Ive also add another code in the attachments which is for a smartphone app if you maybe could change it a bit and use that!!
Help is very much appreciated Thanks ahead!
I now its a much info :smiley:
ArduinoNanowithDelay.ino (874 Bytes)
ESC_Serial_Controller.ino (1.26 KB)
Alright… first, put your code between code tags. Use the </> button in the editor. This way it is horrible to read.
Second, your pictures are not showing, that doesn’t really help
Okey sorry for that! it should now be fixed :smiley:
