| AT |
Attention - Checks if the module is responsive. |
| AT+CPIN |
Enter PIN - Unlocks the SIM card with a PIN. |
| AT+CREG |
Network registration status - Checks network status. |
| AT+CSQ |
Signal quality - Retrieves the current signal strength. |
| AT+COPS |
Operator selection - Manually or automatically selects the network operator. |
| AT+CMGF |
SMS message format - Sets the SMS message format (text or PDU mode). |
| AT+CMGS |
Send SMS - Sends a text message. |
| AT+CMGL |
List SMS messages - Lists received SMS messages. |
| AT+HTTPINIT |
HTTP initialize - Initializes the HTTP service. |
| AT+HTTPPARA |
HTTP parameter - Sets parameters for HTTP operations. |
| AT+HTTPACTION |
HTTP action - Executes an HTTP action (GET, POST, etc.). |
| AT+HTTPTERM |
HTTP terminate - Terminates the HTTP service. |
| AT+CGATT |
GPRS attach or detach - Attaches or detaches from the GPRS network. |
| AT+CIPSHUT |
TCP/IP stack shutdown - Shuts down the TCP/IP stack. |
| AT+CIPSTATUS |
TCP/IP status - Checks the status of the TCP/IP stack. |
| AT+CIPSTART |
Start a TCP/UDP connection - Initiates a TCP or UDP connection. |
| AT+CIPSEND |
Send data in single or multiple frames - Sends data over an established connection. |
| AT+CIPCLOSE |
Close TCP/UDP connection - Closes an established TCP or UDP connection. |
| AT+CIFSR |
Get local IP address - Retrieves the local IP address. |
| AT+CLTS |
Get local timestamp - Retrieves the local timestamp. |
| AT+CCLK |
Set or query real-time clock - Sets or queries the real-time clock. |
| AT+CSMP |
Set text mode parameters - Sets parameters for sending text messages. |
| AT+CMEE |
Enable or disable extended error reporting - Controls error reporting format. |
| AT+CNMI |
New message indication - Sets indication of new received messages. |
| AT+CMGR |
Read SMS message - Reads a specific SMS message. |
| AT+CMGD |
Delete SMS message - Deletes a specific SMS message. |
| AT+CUSD |
Unstructured Supplementary Service Data - Sends or receives USSD messages. |
| AT+CLIP |
Caller ID presentation - Enables or disables caller ID presentation. |
| AT+COLP |
Connection-oriented line presentation - Enables or disables connection-oriented line presentation. |
| AT+CLIR |
Calling line identification restriction - Enables or disables calling line identification restriction. |
| AT+COLR |
Connection-oriented line restriction - Enables or disables connection-oriented line restriction. |
| AT+CLVL |
Speaker volume level - Sets the speaker volume level. |
| AT+CMIC |
Microphone gain - Sets the microphone gain. |
| AT+CRSL |
Ringer level - Sets the ringer level. |
| AT+CALA |
Alarm - Sets or queries alarms. |
| AT+CALR |
Set or query auto-answer - Sets or queries auto-answer settings. |
| AT+CAMM |
Enable or disable automatic answering mode - Enables or disables automatic answering mode. |
| AT+CAOC |
Advice of charge - Enables or disables advice of charge settings. |
| AT+CAON |
Automatic answer on - Enables automatic answer. |
| AT+CAOF |
Automatic answer off - Disables automatic answer. |
| AT+CRC |
Cellular result codes - Enables or disables cellular result codes. |
| AT+CRS |
| AT+IPR |
Set or query UART baud rate - Sets or queries the UART baud rate. |
| AT+IFC |
Set or query hardware flow control - Sets or queries hardware flow control. |
| AT+ICF |
Set or query framing format - Sets or queries framing format. |
| AT+GMM |
Request manufacturer identification - Requests the manufacturer identification. |
| AT+GSN |
Request product serial number identification - Requests the product serial number. |
| AT+GMR |
Request firmware version identification - Requests the firmware version. |
| AT+CPBW |
Write phonebook entry - Writes an entry to the phonebook. |
| AT+CPBR |
Read phonebook entry - Reads an entry from the phonebook. |
| AT+CSCA |
Service Center Address - Sets or queries the Service Center Address for SMS. |
| AT+CSMP |
| AT+CSAS |
Save settings in profile - Saves current settings in a profile. |
| AT+CRES |
Restore settings from profile - Restores settings from a saved profile. |
| AT+CR |
| AT+CRC |
| AT+CRF |
| AT+CRS |
| AT+CDIP |
| AT+CCFC |
Call Forwarding Control - Controls call forwarding. |
| AT+CSCA |
| AT+CSCB |
Select Cell Broadcast Messages - Configures settings for cell broadcast messages. |
| AT+CSDH |
Select Display Parameters of Cell Broadcast Messages - Configures display parameters for cell broadcast messages. |
| AT+CSDT |
Select Data Coding Scheme of Cell Broadcast Messages - Configures data coding scheme for cell broadcast messages. |
| AT+CSTA |
Call Status Change Indication - Controls indication of call status changes. |
| AT+CSQ |
| AT+CSSN |
Supplementary Services Notification - Controls supplementary services notification. |
| AT+CTA |
Tape Answer - Controls tape answer. |
| AT+CTFR |
Termination of File Retrieval - Terminates file retrieval. |
| AT+CTO |
Tape Operation - Controls tape operation. |
| AT+CUSD |
| AT+CURC |
URC Reporting Control - Controls unsolicited result code (URC) reporting. |
| AT+CVHU |
Voice Hang-Up - Hangs up voice call. |
| AT+DDET |
Dual-Tone Multi-Frequency (DTMF) Detection Control - Controls DTMF detection. |
| AT+DLPF |
DTMF Low-Pass Filter Control - Controls DTMF low-pass filter. |
| AT+DDET |
| AT+DR |
DTMF Response - Controls DTMF response. |
| AT+DS |
Dial Status - Reports dial status. |
| AT+DSC |
Dial Command String - Specifies command string for dialing. |
| AT+DSI |
Dial Status Indication Control - Controls dial status indication. |
| AT+DSR |
Dial Status Report - Reports dial status. |
| AT+DST |
Dial Status Termination - Terminates dial status reporting. |
| AT+DTMF |
Send DTMF Tone - Sends a DTMF tone during a voice call. |
| AT+EGCI |
Extended Cellular Information - Requests extended cellular information. |
| AT+ES |
Echo Suppression - Enables or disables echo suppression. |
| AT+ESC |
Escape Sequence Guard Time - Sets escape sequence guard time. |
| AT+ETBM |
Enhanced Transparent Bit Mode - Enables or disables enhanced transparent bit mode. |
| AT+EVRC |
Enhanced Variable Rate Codec - Configures enhanced variable rate codec. |
| AT+FCLASS |
Fax Communication Mode - Sets fax communication mode. |
| AT+FLO |
Flow Control Control - Controls flow control. |
| AT+FCLASS |
| AT+FAC |
Automatic Calling Control - Controls automatic calling. |
| AT+FBS |
Fax Basic State Control - Controls basic fax state. |
| AT+FBV |
Fax Binary File Viewer - Views binary fax file. |
| AT+FCC |
Fax Compression Control - Controls fax compression. |
| AT+FGF |
Fax Graphics Format Control - Controls fax graphics format. |
| AT+FLI |
Fax Local ID - Sets or queries local ID for fax. |
| AT+FLO |
| AT+FMS |
Fax Modulation Scheme Control - Controls fax modulation scheme. |
| AT+FNS |
Fax Negative Response Control - Controls fax negative response. |
