hi all
i am make an arcade . i need help in make a timer to countdown when coin is increted. one coin should add 3 min to the lcd. if another coin is added 3 more min will be added. and if the time runs out a relay will be triggered.
help plz
hi all
help plz
When the first coin is inserted set a timer to 180,000 milis and save startmillis.
Each time through loop, take startmillis from current millis, subtract from timer. If timer is zero then time is up.
If another coin dropped during active time, add 180,000 millis to timer. And save new startmillis
Each time through loop do as above.
Weedpharma
can help with code or plz forward me any.
hi i got code can someone help me modify this and make it simple.
this has so many extra feature which i dont need for my project.
i just need simple system like when the arduino is on the 16x2 LCD shows insert coin and ones coin is inserted the countdown starts from 3min and if another coin is added 3 more min will be added to current tine remaining. and when the time runs out the relay is turned off.
this is all i need.
The guy how made this code has many features which i dont want.
this is were i got the code from https://adambyers.com/2013/09/coin-operated-xbox/
sketch_jan09a.ino (15.4 KB)
When you have done the basic removal of unwanted features show us the code for any further suggestions on improving it.
So far you have not done any of the work, just found someone else's code.
Weedpharma
hi every one
i got this normal timer from french website but its almost want i need. can u help me in a small thing.
when it shows "Time is up" then after a few seconds i want it to go back to start showing the welcome msg. (like a loop).
i try resetting the arduino with digital pin connected to the reset pin and calling from the code but it didnt work.
where i added line u wil see //<<<<<<<<<<<<<< i added this
thanks any help appreciated
arduino CondownTimer
by Markus Klingler
5min-70min
set time in steps of 5 minutes with a button
//liberys
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 11, 12);
//pins
const byte button = 10; //the button (conectet to ground)
const byte buzzer = 8; //a piezo buzzer (conectet to ground)
const byte bgr = 9; //backgroundlight from lcd (conectet to ground)
const byte outp = 7; //an output pin, it drivs up when time's up
const byte testled = 13; //<<<<<<<<<<<<<< i added this
byte readbutton =1;
//values -why it dos'nt work with unsigned long?
double time =0; //the absolutly time in microseconds
double timeb =0; //the restly time till the end - it displayt on lcd in minutes and seconds
double secondsa=0; //values to convert "timeb" to display it on lcd in seconds and minutes
int secondsb=0;
double secondsc=0;
int minutes=0;
double timebgr=0; //for backlight timeout
double mic=0;
void setup(){
//set inputs and outputs
pinMode(button, INPUT);
digitalWrite(button,1);
pinMode(buzzer, OUTPUT);
pinMode(bgr, OUTPUT);
digitalWrite(bgr, HIGH);
pinMode(outp, OUTPUT);
pinMode(outp,LOW);
//init lcd
lcd.begin(16, 2);
lcd.clear();
//display welcome message
lcd.print(" ready to play");
lcd.setCursor(0,1);
lcd.print(" by MakerMan ");
delay(2000);
//clear lcd
lcd.clear();
lcd.print(" incert coin");
// main Loop
void loop(){
//convert timeb value
secondsa=timeb/1000000;
minutes=secondsa/60;
secondsc=minutes*60;
secondsb=secondsa-secondsc;
//and print it to lcd
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
if(minutes<10){
lcd.print("00");
lcd.setCursor(1,1);
lcd.print(minutes);
lcd.setCursor(2,1);
lcd.print(":");
lcd.setCursor(3,1);
lcd.print(" ");
lcd.setCursor(3,1);
if(secondsb<10){
lcd.print("00");
lcd.setCursor(4,1);
lcd.print(secondsb);
delay(50);
//--------------------------------countdown
if(time!=0){ //count only time isn't 0 (button dos'nt pressd)
lcd.setCursor(0,0);
lcd.print("time left");
timeb=time-micros();
mic=micros();
if(timebgr<mic){ //Backlight timeout - check if button 2 seconds dosn't pressd
// analogWrite(bgr, 80); //and dimm the backlight of lcd
digitalWrite(testled,HIGH); //<<<<<<<<<<<<<< i added this
//time's up (end loop)
while(timeb<=0){
digitalWrite(outp,HIGH);
lcd.setCursor(0,0);
lcd.print("Time is up ");
tone(buzzer, 1100);
noTone(buzzer);
// digitalWrite(bgr,LOW);
// delay(500);
// digitalWrite(bgr,HIGH);
digitalWrite(testled,LOW); //<<<<<<<<<<<<<< i added this
//--------------------------------button and timeseting
//read button
readbutton= digitalRead(button);
//button presed
if(readbutton==LOW){
delay(50);
if(time==0){ //do this if time = 0 (while starting, if button pressed fist)
time=time+micros();
timeset(); //call sub: timeset
//set the time
mic=micros();
if(timebgr>mic){ //set time if backlight 100% - else no
timeset();
timebgr=micros()+2000000; //for backlight timeout
readbutton=digitalRead(button);
while(readbutton==LOW){
delay(50);
//======================================sub: timeset
// to set time while button pressed
void timeset(){
// tone(buzzer, 1100, 50);
if(time<42000000){ //add 5 minutes if time smaler then 70 minutes (the overflowpoint of micros();)
time=time+5000000; //time + 5 minutes
}else{ //or no if biger then 70 minutes
lcd.setCursor(0,0);
lcd.print("Max Time reached");
delay(750);
