I'm so so so sorry, I'm sure this question has probably been asked and answered numerous times, I've searched the forum but can seem to find an answer.
I'm ready to put my project into a case and I want to make the connections permanent (I'm currently using dupont cables but I want something more permanent).
Here's my questions.
Is it ever a good idea to solder to the bottom of the arduino? Am I smoking crack?
Was considering using hot glue to attach the dupont cables. Is this asking for trouble?
Thought about also using hot glue and header pins (hot glue the header pins into the header socket and then soldering onto the header pin).
I have the horrible feeling I'm being incredibly stupid. I'm a total noob, apologies in advance for idiocy!
Thanks so so much
Mark
Keep in mind, Nano clones can be purchased with bare holes (i.e. pin headers for you to solder in are included separately). If your project only needs a few connections, this is a good way to proceed. In a couple of cases, I've soldered the needed wires into the Nano, then hot-glued the wires to the bottom of the Nano for mechanical stability. Works really well (esthetics notwithstanding).
C
