Making Arduino Yun WiFi connection reset
I trying the following scheme to ensure the stable WiFi connection with Yun device.
  1. on connection failure : reboot Yun (WiFi core)
  2. set the bridge started variable to 0
  3. begin the bridge again
bridge lib change :
//extern Serial_ Serial; //for debugging
void BridgeClass::begin() {
char c;
if (started) {
uint8_t quit_cmd = {'X', 'X', 'X', 'X', 'X'};
max_retries = 1;
transfer(quit_cmd, 5);
stream.print(CTRL_C);
delay(250);
stream.println("boot"); //in case we are in the bootloader
stream.println("reboot"); //in case we are in the shell
started = true;
stream.setTimeout(5000);
// Wait for U-boot to finish startup
//while(stream.readBytes(&c, 1)) Serial.print(c); //for debugging
while(stream.readBytes(&c, 1));
stream.setTimeout(1000);
