Making arrays into 2d array
hi so recently i made a code that uses frames(that are being shown as array of rows as in MD_MAX72xx convention
and i cant make the 2d array from those frames
can anyone help?
#include <MD_MAX72xx.h>
#include <SPI.h>
// led display
#define HARDWARE_TYPE MD_MAX72XX::PAROLA_HW
#define MAX_DEVICES 1
#define CLK_PIN   13
#define DATA_PIN  11
#define CS_PIN    10
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
MD_MAX72XX ledDisplay = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
//switch
#define button_input A0
const byte T[8] = {
  B11111111,
  B11111111,
  B01111110,
  B00011000,
  B00011000,
  B00011000,
  B00011000,
  B00011000
const byte Z[8] = {
  0b11111111,
  0b11111111,
  0b00001110,
  0b00011100,
  0b00111000,
  0b01110000,
  0b11111111,
  0b11111111
   pinMode(button_input, INPUT);
  ledDisplay.begin();
  ledDisplay.control(MD_MAX72XX::INTENSITY, 0);
  ledDisplay.clear();
  if(digitalRead(button_input)== HIGH)
>     **byte frams[]  = {Z, T};**
printSpinRun(ledDisplay, frams, 25, 30, 3000);
void print_led(MD_MAX72XX display ,byte to_print[]){
  for(int i=0; i<8; i++){
    display.setRow(0, i, to_print[i]);
void printSpinRun(MD_MAX72XX display, byte frames[2][8], int max, int min, int maxRepTime){
  int repetitionsLeft = random(max, min);
  while(repetitionsLeft > 0 ){
    print_led(display, frames[repetitionsLeft % (sizeof(frames)/sizeof(frames[0]))]);
    delay(maxRepTime / repetitionsLeft);
    repetitionsLeft--;
too much definitions
simplify your sketch to definition of 2 1D arrays for input and 1 2D array for output
The T's are 2Darray[ index ][ 0 ] and the Z's are the .......[ 1 ]
const byte name_me_what_I_am[8][2] = {
  B11111111,  0b11111111,
  B01111110,  0b00001110,
  B00011000,  0b00011100,
  B00011000,  0b00111000,
  B00011000,  0b01110000,
  B00011000, 0b11111111,
Although it does work as is, for making clear where the rows are, one usually add extra {}
const byte name_me_what_I_am[][2] = {
  {0b11111111,  0b11111111},
  {0b01111110,  0b00001110},
  {0b00011000,  0b00011100},
  {0b00011000,  0b00111000},
  {0b00011000,  0b01110000},
  {0b00011000,  0b11111111},
(And OP should decide either for arduino’s Bxxxxxxxx or the standard 0bxxxxxxx for coherence)
Not sure this is what makes sense though - looking into the shapes the first column looks like a T letter with a fat top bar and the second column looks like a Z letter.
It might be easier (contiguous memory access) to have the array reversed and have a size listed as [2][8] (and lay the bytes the right way)
I would have a struct or class called Letter including just an array of 8 bytes and then the collection of glyphs would be an array of Letters. It would be defined in the same way as the [2][8] array but you could have functions tied to the struct for display - and add other attributes like what letter does this represent
That is more clear. Maybe call the 2x8 array font?
Yeah or something like this
struct Letter { // or better with attribute packed
  const char character;
  const uint8_t bitmap[8];
const Letter font[] {
  {'T', 0b11111111, 0b11111111, 0b11111111, …, 0b00011000},
  {'Z', 0b11111111, 0b11111111, 0b00001110, …, 0b11111111},
(using my iPhone at the moment so too lazy to enter type all the bytes)
Trying not to type all... oops!
fixed :wink:
