Hi All,
Why will Arduino not let me make changes when i am in Config H ?? When I try to change values it just pings at me
Mike
Hi All,
Mike
What do you mean by "Config H" ?
Sorry " Configurationh"
Mike
What do you mean by " Configurationh" ?
Where is this file located on your PC ?
I go into Arduino and open Marlin for my 3D Delta printer to change settings I go into Configuration H, when I try to delete a value to change it, it will not let me just makes a ping sound. I have uninstalled twice to day but NO change.
Mike
Do you really have a file named "Configuration H" or is it perhaps "Configuration.H"
Either way, try using another editor such as the excellent Notepad++
Right. So at least we now know the proper name of the file. It is Configuration.h
Can you please post it here, and use code tags when you do (</> top/left of the message editor window), to avoid the text being interpreted as HTML commands.
[quote]
[color=#7E7E7E]/* -*- c++ -*- */[/color]
[color=#7E7E7E]/*[/color]
[color=#7E7E7E] Reprap firmware based on Sprinter and grbl.[/color]
[color=#7E7E7E] Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm[/color]
[color=#7E7E7E] This program is free software: you can redistribute it and/or modify[/color]
[color=#7E7E7E] it under the terms of the GNU General Public License as published by[/color]
[color=#7E7E7E] the Free Software Foundation, either version 3 of the License, or[/color]
[color=#7E7E7E] (at your option) any later version.[/color]
[color=#7E7E7E] This program is distributed in the hope that it will be useful,[/color]
[color=#7E7E7E] but WITHOUT ANY WARRANTY; without even the implied warranty of[/color]
[color=#7E7E7E] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the[/color]
[color=#7E7E7E] GNU General Public License for more details.[/color]
[color=#7E7E7E] You should have received a copy of the GNU General Public License[/color]
[color=#7E7E7E] along with this program. If not, see <http://www.gnu.org/licenses/>.[/color]
[color=#7E7E7E] */[/color]
[color=#7E7E7E] This firmware is a mashup between Sprinter and grbl.[/color]
[color=#7E7E7E] (https://github.com/kliment/Sprinter)[/color]
[color=#7E7E7E] (https://github.com/simen/grbl/tree)[/color]
[color=#7E7E7E] It has preliminary support for Matthew Roberts advance algorithm[/color]
[color=#7E7E7E] http://reprap.org/pipermail/reprap-dev/2011-May/003323.html[/color]
[color=#7E7E7E]/* All the implementation is done in *.cpp files to get better compatibility with avr-gcc without the Arduino IDE */[/color]
[color=#7E7E7E]/* Use this file to help the Arduino IDE find which Arduino libraries are needed and to keep documentation on GCode */[/color]
#include [color=#006699]"Configuration.h"[/color]
#include [color=#006699]"pins.h"[/color]
#ifdef ULTRA_LCD
#if defined(LCD_I2C_TYPE_PCF8575)
#include <[color=#CC6600]Wire[/color].h>
#elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008)
#include <LiquidTWI2.h>
#elif defined(DOGLCD)
#include <U8glib.h> [color=#7E7E7E]// library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/)[/color]
#else
#include <[color=#CC6600]LiquidCrystal[/color].h> [color=#7E7E7E]// library for character LCD[/color]
#endif
#endif
#if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
#include <[color=#CC6600]SPI[/color].h>
#endif
#if defined(DIGIPOT_I2C)
#endif
[/quote]
Thanks for trying, but I suspect that you used the "copy for forum" option, hence the HTML codes in the code.
Can you please edit your post and put a straightforward copy/paste between the code tags.
