Good evening,
I have posted the same issue on github under der FastLED Library but have not received a reply yet. And i really need to solve this problem because the installation is for an event at the end of the month. I was hoping to get some resonance here.
I am thankful for any help I can get.
Thanks in advance.
I have been working on a led project for some time. I recently finished my build of 4 large led matrices, each composed of 4 small 8x8 tiles and trying to control these over 4 different data lines. To achieve this I have also used the Library LEDMatrix and used a custom remapping function, similar to the one offered by NeoPixel for Tiled Matrices.
When running my prgramm the esp8266 randomly goes into reset mode or seems to crash after changing a very large amount of Leds and calling fastled FastLED.show(). Running simple sketches over just one data line with the same esp works fine.
My assumption: there is either something wrong with the power supply or changing that many leds at once simply takes to much time and revokes the watchdog timer.
But after countless hours of trying to really narrow the problem down and trying solutions that worked for other people like, FASTLED_ALLOW_INTERRUPTS 0, WiFi.forceSleepBegin(), flash frq 160hz, different types of delay, yield and and putting capacitors between the power supply of the esp, I am clueless on what to do next. Is it possible to shorten the time to pass the information to the chip on the LED?
My specs:
microcontroller esp8266 Lolin V3 nodeMCU 1.0 ESP12E
power supply 30A 5V (used for all components)
16x 8x8 U-64-LED-Panel
led Type WS2812B
total number of Leds 1048
When i turn on the serial at 115200 baud rate the last process I get on the stack before crashing is:
loop_wrapper()
Here is my code for adding the matrices together and trying to show simple objects:
//#define FASTLED_INTERRUPT_RETRY_COUNT 0
//#define FASTLED_ALLOW_INTERRUPTS 0
#define FASTLED_ESP8266_NODEMCU_PIN_ORDER 1
#include <FastLED.h> //https://github.com/FastLED/FastLED
#include <LEDMatrix.h> //https://github.com/Jorgen-VikingGod/LEDMatrix
#include "ESP8266WiFi.h"
#define DATA_PIN 7
#define DATA2_PIN 2
#define DATA3_PIN 5
#define DATA4_PIN 6
#define COLOR_ORDER GRB
#define CHIPSET WS2812B
#define MATRIX_TILE_WIDTH 8 // width of EACH NEOPIXEL MATRIX (not total display)
#define MATRIX_TILE_HEIGHT 8 // height of each matrix
#define MATRIX_TILE_H 2 // number of matrices arranged horizontally
#define MATRIX_TILE_V 2 // number of matrices arranged vertically
#define MATRIX_SIZE (MATRIX_WIDTHMATRIX_HEIGHT)
#define MATRIX_PANEL (MATRIX_WIDTHMATRIX_HEIGHT)
#define MATRIX_WIDTH (MATRIX_TILE_WIDTHMATRIX_TILE_H)
#define MATRIX_HEIGHT (MATRIX_TILE_HEIGHTMATRIX_TILE_V)
#define NUM_LEDS (MATRIX_WIDTH*MATRIX_HEIGHT)
#define NUM_PANELS 4
#define TOTOALCOUNT NUM_LEDS*NUM_PANELS
// Putting together the 4 tiles for one matrix
cLEDMatrix<MATRIX_TILE_WIDTH, MATRIX_TILE_HEIGHT, HORIZONTAL_MATRIX, MATRIX_TILE_H, MATRIX_TILE_V, VERTICAL_ZIGZAG_BLOCKS> matrix;
#define BRIGHTNESS 50
#define TURQUOISE CRGB(80, 120, 120)
#define PURPLE CRGB(80, 0, 120)
#define YELLOW CRGB(243,146,0)
#define BLACK CRGB(0,0,0)
#define BLUE CRGB(0,0,160)
#define RED CRGB(160,0,0)
CRGBPalette16 simplePalette[] = {TURQUOISE, PURPLE , BLUE, RED};
CRGBPalette16 adobePalette[] = {CRGB(50, 164, 173), CRGB(207, 150, 195), CRGB(136, 85, 158), CRGB(108, 62, 145), CRGB(40, 42, 94)};
CRGBPalette16 bushPalette[] = {CRGB(25, 79, 38), CRGB(18, 99, 47), CRGB(3, 127, 57), CRGB(0, 145, 61), CRGB(0, 157, 88), CRGB(0, 151, 96), CRGB(5, 140, 99)};
CRGBPalette16 warmPalette[] = {CRGB(210, 123, 16), CRGB(194, 25, 27), CRGB(177, 28, 27), CRGB(167, 29, 25), CRGB(139, 26, 21)};
CRGBPalette16 warmOcPalette1[] = {CRGB(80, 190, 200), CRGB(143, 206, 198), CRGB(142, 201, 164), CRGB(172, 208, 133)};
CRGBPalette16 warmOcPalette2[] = {CRGB(12, 176, 191), CRGB(102, 193, 189), CRGB(104, 189, 153), CRGB(146, 197, 118)};
CRGBPalette16 grenishPalette[] = {CRGB(43, 170, 90), CRGB(122, 185, 58), CRGB(118, 184, 43), CRGB(154, 195, 30), CRGB(149, 164, 36), CRGB(134, 106, 41), CRGB(92, 81, 46), CRGB(81, 57, 41), CRGB(48, 40, 35), CRGB(32, 32, 26)};
//unnaturalInfusionPalette: 10 ELEMENTS
CRGBPalette16 unnatInfusionPalette[] = {CRGB(221,75,93), CRGB(188,60,94), CRGB(164,52,123),CRGB(149,47,136),CRGB(119,34,122),
CRGB(221,10,43),CRGB(193,23,40),CRGB(174,24,44),CRGB(132,22,40),CRGB(101,18,33)};
//naturalInfusionPalette: 10 ELEMENTS
CRGBPalette16 natInfusionPalette[] = {CRGB(38,130,130),CRGB(43,132,111),CRGB(56,140,94),CRGB(62,158,72),CRGB(81,176,72),
CRGB(31,66,47),CRGB(36,76,49),CRGB(38,97,44),CRGB(35,125,52),CRGB(41,158,56)};
//BubbleFrontPalette: 5 ELEMENTS
CRGBPalette16 bubbleFrontPalette[] = {CRGB(240, 147, 64), CRGB(237, 125, 50), CRGB(232, 102, 32), CRGB(207, 78, 22), CRGB(193, 45, 24)};
CRGBPalette16 purpleGreen[] = {CRGB(23, 119, 116), CRGB(28, 132, 132), CRGB(41, 120, 150), CRGB(53, 88, 164), CRGB(71, 71, 151), CRGB(90, 90, 164), CRGB(119, 103, 171)};
//CRGBPalette16 pacificaPalette[] = {0x000507, 0x000409, 0x00030B, 0x00030D, 0x000210, 0x000212, 0x000114, 0x000117,
// 0x000019, 0x00001C, 0x000026, 0x000031, 0x00003B, 0x000046, 0x14554B, 0x28AA50
void stableDelay(int delaytime)
yield();
delayMicroseconds(delaytime);
void matrix_clear() {
//FastLED[1].clearLedData();
// clear does not work properly with multiple matrices connected via parallel inputs
memset(matrix[0], 0, TOTOALCOUNT-1);
void total_clear(bool showing)
matrix_clear();
FastLED.clear(showing);
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
//WiFi.setSleepMode(WIFI_NONE_SLEEP);
// Serial.begin(115200);
// WiFi.forceSleepBegin();
// stableDelay(50);
//Serial.println("test");
//delay(100);
//Adding all 4 Matrices into one large led array
FastLED.addLeds<CHIPSET, DATA_PIN, COLOR_ORDER>(matrix[0], 0, matrix.Size());//.setCorrection(TypicalSMD5050);
FastLED.addLeds<CHIPSET, DATA2_PIN, COLOR_ORDER>(matrix[0], matrix.Size(), matrix.Size());//.setCorrection(TypicalSMD5050);
FastLED.addLeds<CHIPSET, DATA3_PIN, COLOR_ORDER>(matrix[0], matrix.Size()*2, matrix.Size());//.setCorrection(TypicalSMD5050);
FastLED.addLeds<CHIPSET, DATA4_PIN, COLOR_ORDER>(matrix[0], matrix.Size()*3, matrix.Size());//.setCorrection(TypicalSMD5050);
//FastLED.setBrightness(BRIGHTNESS);
//total_clear(false);
total_clear(false);
stableDelay(5000);
japan();
stableDelay(5000);
japan2(1);
stableDelay(5000);
total_clear(false);
stableDelay(5000);
void japan()
matrix.DrawFilledRectangle(0, 0, ((16*2) - 1), (5 - 1), CRGB(150, 0, 255));
uint16_t r = min(((matrix.Width()*NUM_PANELS) - 1) / 2, (matrix.Height() - 1) / 2) - 1;
matrix.DrawFilledCircle(((matrix.Width()*1) - 1) , (matrix.Height() - 1) / 2, r, CRGB(255, 0, 0));
FastLED.show();
void japan2(bool c)
if(c)
matrix.DrawFilledRectangle(162, 0, ((164) - 5), 5, CRGB(100, 50, 200));
//uint16_t r = min(((matrix.Width()NUM_PANELS) - 1) / 2, (matrix.Height() - 1) / 2) - 1;
//matrix.DrawFilledCircle(((matrix.Width()NUM_PANELS) - 1) , (matrix.Height() - 1) / 2, r, CRGB(0, 0, 255));
FastLED.show();
matrix.DrawFilledRectangle(163, 0, ((164) - 1), 10, CRGB(100, 50, 0));
//uint16_t r = min(((matrix.Width()*NUM_PANELS) - 1) / 2, (matrix.Height() - 1) / 2) - 1;
//matrix.DrawFilledCircle(((matrix.Width()*NUM_PANELS) - 1) , (matrix.Height() - 1) / 2, r, CRGB(0, 0, 255));
FastLED.show();
void testMatrix()
for (int i_1= 0;i_1< 16; i_1++)
for (int i_2 = 0; i_2< 32;i_2++)
matrix.DrawPixel(i_2, i_1, CRGB(255, 0, 0));
FastLED.show();
matrix.DrawPixel(6, 6, CRGB(255, 255, 0));
FastLED.show();
delay(100);
