Hello everyone, hope all of you are safe during this time. I've come across a dilemma, currently, when certain condition are met, here:
if (x == 0 && b == 0 && y == 0 && a == 0) // All buttons pressed
for (int ixx=0; ixx<4; ixx++)
strip.setPixelColor(ixx, 255, 255, 255);
strip.show();
timer1 = millis();
else if (b == 0 && x == 1 && y == 1 && a == 1 && (ay <= 200)) // B + down
if (k == 0) {
k = 255; }
Charge(100);
when the else if is met, it calls the "Charge" function I created:
void Charge(uint8_t wait)
if (millis() - ktimer > 10)
if (k > 0) {
k = k - 1;
ktimer = millis();
if (millis() - timer > wait)
switch (i) {
case 0:
strip.setPixelColor(0, k , k , 0);
strip.setPixelColor(1, 0 , k , k);
strip.setPixelColor(2, k , k , 0);
strip.setPixelColor(3, 0 , k , k);
case 1:
strip.setPixelColor(0, 0 , k , k);
strip.setPixelColor(1, k , k , 0);
strip.setPixelColor(2, 0 , k , k);
strip.setPixelColor(3, k , k , 0);
case 2:
case 3:
strip.show();
if (j == 255)
j = 0;
j++;
timer = millis();
i = (i + 1) % 4;
//Serial.println(k);
What this does is simply alternate between Cyan and yellow between the 4 Neo pixel Leds i have attached, moving it back and forth. The user would have to input those button press's for a split second, however the issue is that those inputs usually wont stay like that, essentially the else if condition would be no longer met, ceasing the function to be continually run.
Is there a way to make so that as long as its pressed once, it will run the function until k == 0?
I was trying to make it so that when its called, it will set k to 255 and run it until k gets to 0, which then exits the function. Im trying to make it run all the way ( 255 too 0 ) even if the initial condition isn't continuously met, until k gets to 0.
Another thing is I can not use delay with this program, as the arduino has to be able to be interrupted at any point.
Thanks for any help at all
unfortunately I can't post the entire code as it exceeds maximum allowed of characters for the forum. If it is needed i can private message it to you.
Thanks again
CLOUD_NODELAY.ino (11.4 KB)
