Hello,
my Problem is that the KeyboardReprogram Sketch (Examples > Keyboard > KeyboardReprogram) doesn't work on the esplora with german keyboard layout set in system settings ( I use Windows 11 with german keyboard on my laptop).
I modified the sketch to write the Esplora commands, but it only types strange things, for example a - where there should be a / or such things.
my Sketch:
Arduino Programs Blink
This sketch demonstrates the Keyboard library.
For Leonardo and Due boards only.
When you connect pin 2 to ground, it creates a new window with a key
combination (CTRL-N), then types in the Blink sketch, then auto-formats the
text using another key combination (CTRL-T), then uploads the sketch to the
currently selected Arduino using a final key combination (CTRL-U).
Circuit:
- Arduino Leonardo, Micro, Due, LilyPad USB, or Yún
- wire to connect D2 to ground
created 5 Mar 2012
modified 29 Mar 2012
by Tom Igoe
modified 3 May 2014
by Scott Fitzgerald
This example is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/KeyboardReprogram
#include "Keyboard.h"
#include "Esplora.h"
#include "KeyboardLayout.h"
// use this option for OSX.
// Comment it out if using Windows or Linux:
char ctrlKey = KEY_LEFT_GUI;
// use this option for Windows and Linux.
// leave commented out if using OSX:
// char ctrlKey = KEY_LEFT_CTRL;
// make pin 2 an input and turn on the pull-up resistor so it goes high unless
// connected to ground:
// initialize control over the keyboard:
Keyboard.begin(KeyboardLayout_de_DE);
while (Esplora.readButton(1) == HIGH) {
// do nothing until pin 2 goes low
// new document:
Keyboard.press(ctrlKey);
Keyboard.press('n');
delay(100);
Keyboard.releaseAll();
// wait for new window to open:
// versions of the Arduino IDE after 1.5 pre-populate new sketches with
// setup() and loop() functions let's clear the window before typing anything new
// select all
Keyboard.press('a');
// delete the selected text
Keyboard.write(KEY_BACKSPACE);
// Type out "blink":
Keyboard.println("#include <Esplora.h>");
Keyboard.println("void setup() {");
Keyboard.println("//nothing to set úp");
Keyboard.println("}");
Keyboard.println();
Keyboard.println("void loop() {");
Keyboard.println("Esplora.writeRGB(255,0,0);");
Keyboard.print("delay(3000);");
// 3000 ms is too long. Delete it:
for (int keystrokes = 0; keystrokes < 6; keystrokes++) {
// make it 1000 instead:
Keyboard.println("1000);");
Keyboard.println("Esplora.writeRGB(0,0,0);");
Keyboard.println("delay(1000);");
// tidy up:
Keyboard.press('t');
delay(100);
delay(3000);
// upload code:
Keyboard.press('u');
delay(100);
// wait for the sweet oblivion of reprogramming:
while (true);
EDIT: I solved it by using the new feature to set keyboard layout
