Making led fade on when switch is on and then it turns off when switch is off
I'm having trouble doing exactly what the title says. I need an led strip to fade on when a switch is turned on and then when the switch its turned off I need the led strip to turn off. I'm new to Arduino and would like some help with code. What I have so far makes the led strip fade on and then goes off and fades back on. I can get it to turn off by toggling the switch, though. I need it to fade on and stay on until the switch is hit, then turn off. Thanks. :slight_smile: P.S. I know the code is a mess, I combined other people's code because I had no idea how to do it myself.
const int buttonPin = 2;
int led = 9; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int buttonState = 0;
int fadeValue = 0;
int run;
// the setup routine runs once when you press reset:
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
run = 0;
// the loop routine runs over and over again forever:
if (digitalRead(buttonPin) == LOW) //funcitons based off of button pulling input pin LOW
if (run == 0)
run = 255;
run = 0;
if (run > 0)
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
// fade in from min to max in increments of 5 points:
for (fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
// sets the value (range from 0 to 255):
analogWrite(led, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(30);
// turn LED off:
digitalWrite(led, LOW);
brightness = 0;
fadeValue = 0;
what are you trying to achieve with your run variable?
what you need to do is remember once you've done the for (fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) loop to not do that again until the button is released
const int led = 9;      // the PWM pin the LED is attached to
const int fadeAmount = 5;    // how many points to fade the LED by
  if (digitalRead(buttonPin) == LOW) {
    // Switch is ON
    brightness += fadeAmount;
    brightness = constrain(brightness, 0, 255);
    // Switch is OFF
    brightness = 0;
  analogWrite(led, brightness);
  delay(30);
ahh id try just putting a large cap across + and ground(-) of LED I know PWM works when arduino is on
but not when it is off ?
Not sure what I did but it works now. Thanks guys!
int fadeValue = 0;
int run;
pinMode(13, OUTPUT);
pinMode(11, OUTPUT);
run = 0;
if (run == 0)
run = 255;
run = 0;
if (run > 0)
if (buttonState == LOW ) {
digitalWrite(11, HIGH);
delay(100);
for (fadeValue = 0 ; fadeValue <= 255; fadeValue += 3) {
delay(30);
if (fadeValue > 254 && digitalRead(buttonPin) == LOW) {
while (digitalRead(2) == LOW) {
// Do nothing
delay(100);
// turn LED off:
digitalWrite(11, LOW);
brightness = 0;
fadeValue = 0;
I know PWM works when arduino is on but not when it is off ?
Why would you expect PWM to work when the Arduino is off?
