Hi there
I am a math teacher (not computer sciences ! ) and we would like to build a music instrument (measure data & sonify it... for the time being we are trying using Yun movements).
I am reading the mpu6050 accel/gyro data on the Arduino 32u4 (sketch side) at 200 Hz and I am struggling to transfer it to the linino side to process it and send it in OSC via wifi (using pyOSC).
In a first approach, I was doing this exclusively on the sketch side (including the OSC part) but it was desperately slow. Inspired by ShapeShifter, I tried to use serial1 to transfer the data on the linino side to format/send the OSC message directly in the linino.
Here is how I tried:
Arduino sketch side (sending the serial1 messages at the end)
#include <Process.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps_V6_12.h"
// make ip and port constants
#define IP_ADR "192.168.1.181"
#define PORT 4560
#define INTERRUPT_PIN 3 // use pin 15 on ESP8266
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
#define OUTPUT_READABLE_WORLDACCEL
//#define OUTPUT_TEAPOT
// MPU control/status vars
uint8_t ratediv = 4; // set the sample rate to 100 Hz
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 gy; // [x, y, z] gyro sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// === INTERRUPT DETECTION ROUTINE ===
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
// === INITIAL SETUP ===
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
while (!Serial); // wait for Leonardo enumeration, others continue immediately
// initialize serial1 communication
Serial1.begin(115200);
[... varied MPU init [...]
// === MAIN PROGRAM LOOP ===
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize) {
if (mpuInterrupt && fifoCount < packetSize) {
// try to get out of the infinite loop
fifoCount = mpu.getFIFOCount();
// other program behavior stuff here
// reset interrupt flag and get INT_STATUS byte
mpuIntStatus = mpu.getIntStatus();
// get current FIFO count
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & (0x01 << MPU6050_INTERRUPT_FIFO_OFLOW_BIT)) || fifoCount >= 1024) {
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
} else if (mpuIntStatus & (0x01 << MPU6050_INTERRUPT_DMP_INT_BIT)) {
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetEuler(euler, &q);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
mpu.dmpGetAccel(&aa, fifoBuffer);
mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
String acc = String(aaWorld.x) + "," + String(aaWorld.y) + "," + String(aaWorld.z) + "\n";
Serial1.print(acc);
delay(2);
String gyr = String(int(ypr[0]*180/PI)) + "," + String(int(ypr[1]*180/PI)) + "," + String(int(ypr[2]*180/PI)) + ",END\n";
Serial1.print(gyr);
delay(2);
Linino python OSCsender.py script:
#!/usr/bin/python -u
import OSC
import serial
import re
# Setup the client connection
host = "192.168.1.181"
port = 4560
adr = "/yunMusic"
# initiate udp client and connect
client = OSC.OSCClient()
client.connect( (host, port) )
# instantiate a serial1 object
serialobj = serial.Serial('/dev/ttyATH0', 115200, timeout = 1)
# initialize an OSC message object, set adr
msg = OSC.OSCMessage(adr)
while True:
if serialobj.inWaiting() >= 0:
# Read a new line from the serial1 and split into values
values = serialobj.readline().decode("ascii").split(",")
for value in values:
vals = re.findall('-?\d+\.?\d*',value)
if "END" not in value:
if len(vals) > 0:
for val in vals:
msg.append(int(val)) # just append the values
else:
i = value.find("END")
if i > 0:
if len(vals) > 0:
for val in vals:
msg.append(int(val)) # append the values before
client.send(msg) # Send the OSC message after
else:
client.send(msg) # Send the OSC message before
msg = OSC.OSCMessage(adr) # append the values after
if len(vals) > 0:
for val in vals:
I still have to launch manually the python script for it, even if I included in my /etc/rc.local:
python /root/OSCtoPD/OSCsender.py
And when it works (sends OSC data on the network), it does not read and format the data as I would like. It should send at the adress "/yunMusic" something formatted like [accx, accy, accz, gyrx, gyry, gyrz] but it is often splited into [accx, accy, accz] and [gyrx, gyry, gyrz] or on the contrary concatenates several messages [accx, accy, accz, gyrx, gyry, gyrz, accx, accy, accz, gyrx, gyry, gyrz, accx, accy, accz, gyrx, gyry, gyrz, ....], or do nothing (not any OSC messages sent), or simply crashes with a posix error (multiple attempts to access to the serial which says it ready to be read and returning nothing).
How should I transfer/format these data from 32u4 to linino and how should I decode them in the python script ? (serial1.write() instead of serial1.print() ?)
Should I simply use another Arduino with a wifi shield to get an easier life ?
Any help would be greatly appreciated, this is for a project at school and I am a bit stuck.
Best,
Jeff
