Making my own symbol font ???
Hello, is there any tool to make it, or a link where I can read how to do??
Thanks
Symbol font for what? You don't give enough information.
Sorry.
I am working with buttons por a TFT, and you can assign images of a symbolfont for these buttons.
I have seen differents kinds of symbolfonts to use with buttons, but I would like to draw my own symbols.
May be better in Displays forum?? Mmm
pabusa:
Thanks
I usually make my bitmaps by hand (if there are only a few that I need). The ones I make are for a VFD display, which is tricky because each byte generates an 8 pixel vertical line with the LSB on top and the MSB on the bottom.
To convert a normal bitmap, I need to rotate it CCW, and then in blocks of 8 (a royal pain - which is why I make my own by hand).
I made this little guide for generating 8x8, 8x16, 16x8 and 16x16 bitmaps. I just draw in the pixels, then read off the hex values. Hope this is of some help…
Mmm… well, first of all thank you, but I still not understand what to do.
By now, I see, that I can put a file named myfont.c in the same directory of my sketch and then “import” and use… Could we see in an example???
I am having a glance to a “font file” … I see a kind of array with info and I think that “the definition of the font”:
// Ubuntu.c
// Font type    : Full (95 characters)
// Font size    : 24x32 pixels
// Memory usage : 9124 bytes
#if defined(__AVR__)
	#include <avr/pgmspace.h>
	#define fontdatatype const uint8_t
#elif defined(__PIC32MX__)
	#define PROGMEM
	#define fontdatatype const unsigned char
#elif defined(__arm__)
	#define PROGMEM
#endif
fontdatatype Ubuntu[9124] PROGMEM={
(I try to understand)
and then it is supposed it es for letter “A”
0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x7E,0x00,0x00,0x7E,0x00,0x00,0xFF,0x00,0x00,0xF7,0x00,0x00,0xE7,0x00,0x00,0xE7,0x00,0x01,0xE7,0x80,0x01,0xC3,0x80,0x01,0xC3,0x80,0x03,0xC3,0xC0,0x03,0xC1,0xC0,0x03,0x81,0xC0,0x03,0x81,0xC0,0x07,0x81,0xE0,0x07,0xFF,0xE0,0x07,0xFF,0xE0,0x07,0xFF,0xE0,0x0F,0x00,0xF0,0x0E,0x00,0x70,0x0E,0x00,0x70,0x0E,0x00,0x70,0x1E,0x00,0x78,0x1C,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
I think that these hex numbers define the “black dot in the matrix”… but…
1 - How I know that “that letter” belongs to the “A letter in my keyboard”???
2 - What is the relation with the “matrix” you tell me … (although here we talk about bigger dimension)
I am Spanish… how do I suppused to “read off” (the meaning in an example)??
Is there not any tool to generate?
There are many tools. Search for “font generator”.
