Here’s the code…
#include <AlphaNumeric_Driver.h>
#define NUMBER_OF_DISPLAYS 6
// --------- Pin Definitions -----------
int SDIpin = 51;
int CLKpin = 52;
int LEpin = 53;
int OEpin = 50;
alphaNumeric myDisplay(SDIpin, CLKpin, LEpin, OEpin, NUMBER_OF_DISPLAYS); // Create an instance of Alpha Numeric Displays
int gameDelay = 1500; //This is the millisecond delay between “moles” at the start of the game
boolean inPlay = 1; //This is a boolean flag that we’ll use to determine where in the scoring cycle we are
//Serial.begin(9600); //Pour a bowl of Serial… for debugging
//LED SETUP - Here’s all of the pins we’ll need to use. First we set them as outputs, then we make sure they’re low.
pinMode(22, OUTPUT); pinMode(23, OUTPUT); pinMode(24, OUTPUT); pinMode(25, OUTPUT);
pinMode(26, OUTPUT); pinMode(27, OUTPUT); pinMode(28, OUTPUT); pinMode(29, OUTPUT);
pinMode(6, OUTPUT); digitalWrite(6, LOW);
digitalWrite(22, LOW); digitalWrite(23, LOW); digitalWrite(24, LOW); digitalWrite(25, LOW);
digitalWrite(26, LOW); digitalWrite(27, LOW); digitalWrite(28, LOW); digitalWrite(29, LOW);
//BUTTON SETUP - Here’s all of the pins we’ll need for the buttons. First set them as inputs, then set the internal pull-ups.
//Yes, I could have use a FOR loop for a lot of this.
pinMode(38, INPUT); pinMode(39, INPUT); pinMode(40, INPUT); pinMode(41, INPUT);
pinMode(42, INPUT); pinMode(43, INPUT); pinMode(44, INPUT); pinMode(45, INPUT);
digitalWrite(38, HIGH); digitalWrite(39, HIGH); digitalWrite(40, HIGH); digitalWrite(41, HIGH);
digitalWrite(42, HIGH); digitalWrite(43, HIGH); digitalWrite(44, HIGH); digitalWrite(45, HIGH);
//Let’s get ready to rumble.
//Tell the stupid human what to do:
while (anyKey() == 0) {
myDisplay.scroll(“P”, 300);
if(anyKey() == 1)
myDisplay.scroll(“R”, 300);
if(anyKey() == 1)
myDisplay.scroll(“E”, 300);
if(anyKey() == 1)
myDisplay.scroll(“S”, 300);
if(anyKey() == 1)
myDisplay.scroll("S ", 300);
if(anyKey() == 1)
myDisplay.scroll(“A”, 300);
if(anyKey() == 1)
myDisplay.scroll(“N”, 300);
if(anyKey() == 1)
myDisplay.scroll("Y ", 300);
if(anyKey() == 1)
myDisplay.scroll(“B”, 300);
if(anyKey() == 1)
myDisplay.scroll(“U”, 300);
if(anyKey() == 1)
myDisplay.scroll(“T”, 300);
if(anyKey() == 1)
if(anyKey() == 1)
myDisplay.scroll(“O”, 300);
if(anyKey() == 1)
myDisplay.scroll("N ", 300);
if(anyKey() == 1)
if(anyKey() == 1)
myDisplay.scroll("O ", 300);
if(anyKey() == 1)
if(anyKey() == 1)
myDisplay.scroll(“L”, 300);
if(anyKey() == 1)
if(anyKey() == 1)
if(anyKey() == 1)
} //Wait for an input, the anyKey function throws TRUE when it gets a press
gameDelay = 1000; //Another chance to play with the game delay
inPlay = 1; //Reset the inPlay flag from last game
playagame(); //Whack some moles
//This function (anyKey) just looks for a button press on any of the 16 buttons and throws a flag.
//Similar functions are usueful in a lot of different applications.
boolean anyKey() {
boolean press = 0;
if (
digitalRead(38) == LOW || digitalRead(39) == LOW || digitalRead(40) == LOW || digitalRead(41) == LOW ||
digitalRead(42) == LOW || digitalRead(43) == LOW || digitalRead(44) == LOW || digitalRead(45) == LOW) {
press = 1;
return press;
//It’s time to whack some moles, here comes the fun:
void playagame() {
String scorestr; //This is the string that we’ll put the score into before we display it
int score = 0; //This is the “mathy” version of the score that we’ll increment in code
int newLight; //This is the number of the LED that we’re goign to light next
boolean hit = 1; //This is the flag that tells the scoring engine whether or not to give you the hor… umm, car horn.
randomSeed(analogRead(A0)); //Seed the pseudo-random engine with some true randomness.
delay(1000); //give everyone a second to chill
myDisplay.clear(); //Clear the display
myDisplay.scroll(" READY", 100); //Well? Are you?
delay(2000); //Two seconds of mind-bending suspense
myDisplay.scroll(" SET ", 100);
delay(1500); //Two seconds of mind-bending suspense
myDisplay.scroll(“GO”, 50); //GO! DO IT NOW!
while (inPlay == 1) {
inPlay = 0; //Assumed guilty until proven innocent
newLight = random(22, 29); //Pick a random light
//Serial.println(newLight); //Serial debug stuff
int newButtn = getButtn(newLight); //The getButtn function returns the button number corresponding to the LED that’s lit.
digitalWrite(newLight, HIGH); //Light up the random light.
for (int t = 0; t < gameDelay; t++) { //Okay, I said it was a millisecond value, but it’s really a cycle count value. This is the amount of time you have. Go.
hit = digitalRead(newButtn); //Grab the button status
if (hit == 0) {
inPlay = 1; //if you get a button press: proven innocent.
delay(1);
} //take a breather
digitalWrite(newLight, LOW); //now that you’ve either slapped that mole or not, we need it to go back in it’s hole
score = score + 5; //give 'em a few points
gameDelay = gameDelay - 5; //make the game faster
tone(10, 1240, 250); //Play a beepy sound
scorestr = String(score); //Turn the mathy score into a stringy score
scorestr.trim(); //chop off the end
myDisplay.clear(); //clear the display
myDisplay.print(scorestr.charAt(0)); myDisplay.print(scorestr.charAt(1)); myDisplay.print(scorestr.charAt(2)); myDisplay.print(scorestr.charAt(3)); myDisplay.print(scorestr.charAt(4));
} //This is my attempt to correctly display a score that was tranformed from an integer… it doesn’t work.
myDisplay.clear(); //So if you’ve made it this far in the code, you’ve lost. (Pro-Tip: You always lose eventually)
digitalWrite(6, HIGH); //HONK
delay(500); //STILL HONKING
digitalWrite(6, LOW); //Okay, if the powersupply hasn’t locked-down or browned out your Arduino we can turn off the horn. (8 Amps?!?!)
myDisplay.scroll(“GOTCHA”, 300); //Har Har Har
tone(10, 240, 2550); //Play a beepy sound
delay(3000);
myDisplay.scroll(" YOUR SCORE ", 200); //Here’s your score (ish)
delay(3000);
myDisplay.clear(); //Again with the not-so-good score display
delay(2000); //Flash it on and off, like an Arcade machine.
myDisplay.off(); //off?
myDisplay.on(); //on!
myDisplay.on(); //on! Isn’t this fun?
myDisplay.on();
delay(1500);
myDisplay.clear();
//Here’s the function that returns the corresponding switch pin for a given LED pin.
//It’s just a massive switch-case
int getButtn(int newLight) {
int Buttn;
switch (newLight) {
case 22:
Buttn = 38;
case 23:
Buttn = 39;
case 24:
Buttn = 40;
case 25:
Buttn = 41;
case 26:
Buttn = 42;
case 27:
Buttn = 43;
case 28:
Buttn = 44;
case 29:
Buttn = 45;
return Buttn; //Button, button, whose got the button?
