You can also buy plain LED's that are single color Red, Blue etc - but that would not give you the white you are thinking about
Another idea for the controller: Digispark. Relatively easy for a beginner, compared to standalone atmega, ISP shields etc, not quite as easy to use as a Nano, but smaller.
Save the Digispark for an improved version one day.
Working with the Digispark is just adding potential problems. Why I know?
I’ve just finished moving a fully working all done program from a UNO onto a Digispark. Even so, it was a challenge. At least
Weird programming method, 100 percent unpredictable. Now with my “magic cable” and adapter, I can get the Digispark reprogrammed about once in 3 or 4 attempts. Various errors, or just works. Naturally the faster I want to work on this thing, the less likely a download is to succeed.
No serial port serial monitor, so that’s why I didn’t even try until I thought I had finished.
Some libraries aren’t available. Why I learned how to do direct port manipulation and wrote my own fastLED kinda code…
The IDE compiler will cheerfully build a program that uses 140 % of you random access memory and never say a word about how that might actually be a deal breaker. So my little project has fewer LEDs and I am looking at ways to eliminate the requirement that the strip have a buffer of contents at all.
That last one kept me too busy for too long with dozens of failed uploads and you’ve caught me at a bad time for letting anyone go off and work with a Digispark, esp. in the expand and explore phase of a project.
The Digispark is a darling little thing, tho, agreed. But only a small step up from dealing with a bare chip.
Some tiny Arduino style boards are almost as small and suffer no particular disadvantages.
a7
@alto777, I agree your warnings and concerns are fair. That's why I presented it as an idea and attached the caveats I mentioned.
My experience has been a little better that yours. Maybe 1 in 4 uploads fail for me, but it is still annoying. I have used the Adafruit NeoPixel library with Digispark and standalone attiny85 successfully. Not because of any great expertise on my part, I'm sure, perhaps just luck.
I used one, as an example, to control case lighting in my PC. Only a handful of leds (small case), so no memory problems.
All of this is why I suggested the board in #8. It's a minor ATmega328 variant of a Pro Mini apparently using s later and slightly cheaper chip. I haven't tried it yet (still waiting for them from China of course) so I don't know if it requires a different IDE setting, but it clearly should be code-identical.
Not sure in which tub my Digisparks are, but that is something else for me to play with "one day"; it sounds less than enthusing. First board I bought was a Leostick and that was put aside as baulky to program. First one I got working was a Pro Mini (clone) and dead easy. All-rounder is the Nano (sorry, clone), cheap and versatile. UNO is very inconvenient unless a shield completes the application in one move.
To the OP: You are going to need to solder to assemble virtually any useful project. The Pro Mini (and variant) or Nano can be used with the header pins fitted and a solderless breadboard for prototyping, but for a final soldered version, you would generally solder wires directly to the module itself. If you have a problem with so many wires connecting to one terminal (ground and to a lesser extent, 5 V) it may be more practical to solder it to a piece of "stripboard" or just use a small strip of stripboard to make the multiple connections!
Do not even think of using the "Vin" or "RAW" pin or on a UNO, the Barrel Jack, for powering it! ![]()
@Paul__B Now that there is a board profile for the knockoff microprocessor LGT8F328P on that board and some good use experience, the excitement around using it may have abated. I still think you might be in for an interesting ride and look forward to hearing a report.
Time is money, but it is hard not to take time to enable use of a $0.79 board.
I use the UNO almost exclusively for experimenting. My favorite clone has the female header plugs AND a row next to them of unsolder through-holes, nice for probing.
I have a set of M-M, M-F and F-F 0.1" jumpers, usually I can quickly set up any experiments w/o soldering. Too much.
When I like something enough to permanize it I select from any number of small Aduino compatible boards I have around. I put some pogo pins on a FTDI device so I can program the non-USB boards w/o soldering. Works good.
My Digisparks came out of a bucket (no, a box, but) just for this reason. I had forgotten what a PITA I found them to be lo those many years ago when I picked them up. But I cannot let them just go to waste… once they are cranking away in something I'll just leave them alone. And probably buy no more.
a7
